08-31-2008, 11:10 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Turkey Age: 38
Member: 148781 Status: Offline Sonork: 100.1620312 Thanks Meter: 20 | philips xenium??? i wanna use pinfinder for philips xenium 9@9w which cable i use and select rx tx ? please help me... |
08-31-2008, 12:15 | #2 (permalink) |
Member: 148781 Status: Offline Sonork: 100.1620312 Thanks Meter: 20 | COM4 [VCP0] selected Action: read codes unlock method: read codes Model: Philips-Xenium-9@9w Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect error: boot phase#2/1 failed Can't initialize test mode ! Possible reasons: 1. communication fault, repeat required operation 2. eeprom/ffs serious damaged, use repair eeprom/ffs files or use other unlock/format method error: operation failed ! Finished, time used: 4712 sec Remove/Install battery now ! |
08-31-2008, 13:45 | #3 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 |
08-31-2008, 16:58 | #5 (permalink) |
Product Supporter Join Date: Sep 2004 Location: *In the right way*
Member: 84268 Status: Offline Sonork: 100.114149 Thanks Meter: 2,569 | i don't think that you know how make cable! & how use pinfinder with non chinese phones, Cable name: Philips-390 keyboard down connector 2x5 5: Gnd 6: Phone Rx (RJ45 pin-2) 7: Phone Tx (RJ45 pin-3) check this link: http:///vbb/showthread.php?t=526956 |
08-31-2008, 18:46 | #6 (permalink) |
Member: 148781 Status: Offline Sonork: 100.1620312 Thanks Meter: 20 | it needs reverse. sorry i forgot it. Code: COM3 [VCP0] selected Action: read codes unlock method: read codes Model: Philips-Xenium-9@9w Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing[6227:8A02:8A01]... CPU: MT6227 chip: 0031:64C1:7C0A Connecting, wait... Release Power button now ! Phone detected, wait... Hardware: MT6227,E02 Date: 2005.04.12 Version: 1.0 Version: 0262000410031299 Version: W4C27_HW 44 byte(s) read imei: 35823300184173 connection Ok 148 byte(s) read Phone lock: On Network lock: Off Network subset lock: Off Service provider lock: Off Corporate lock: Off IMSI lock: Off Auto lock: Off Phone code: 1110 Finished, time used: 10 sec Remove/Install battery now ! |
The Following 2 Users Say Thank You to saidgoren For This Useful Post: |
08-31-2008, 22:21 | #9 (permalink) |
Member: 148781 Status: Offline Sonork: 100.1620312 Thanks Meter: 20 | is this phone cloned phone or original philips? http://rapidshare.com/files/14163956...2.B0X.rar.html http://rapidshare.com/files/14164370...6.B0E.rar.html |
The Following User Says Thank You to saidgoren For This Useful Post: |
09-01-2008, 11:57 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, In fact it's possible to build quite good phones based on this chipset, but it's very important to has high-quality production, not like many Chinese factories do. |
09-01-2008, 12:42 | #13 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: Phils
Member: 331390 Status: Offline Thanks Meter: 434 | Quote:
why they just don't make original piece? instead of cloning NOKIA, S.E., etc. | |
09-02-2008, 15:05 | #14 (permalink) | |
Member: 148781 Status: Offline Sonork: 100.1620312 Thanks Meter: 20 | Quote:
its menu is different from other china model although it have mtk cpu. its menu is as good as original phones. so, i ask if it is original or cloned. two sim not work at the same time. only one sim works. i has an option swicth sim card. | |
Philips Xenium 989 | gsm13 | Hardware Repair by brands | 0 | 02-15-2002 07:29 |
What about Philips Xenium 9@9 ? | ReZn0r | Philips | 0 | 11-08-2001 13:55 |
problems with Philips Xenium 9@9 | Ikk | Philips | 1 | 10-14-2001 17:56 |
Philips Xenium Unlock | Erik | Philips | 1 | 10-12-2001 15:57 |
Nokia Language Uploader, Sony Z5/J5, Philips Xenium, Ozeo | VictorGSM | Hardware Equipments for GSM | 0 | 04-18-2001 01:17 |
