Old 05-09-2018, 22:45   #1 (permalink)
seyram's Avatar
Member: 1759904
Thanks Meter: 6
Phone dead after flash need help please
Bro Jay Di please i need you and the entire cm2 team your help to help me recover a clients phone.
i mistakenly flashed a Tecno c9 plus firmware into Tecno c9 phone and now phone dead. phone respond when you connect with pc but screen black.
i tried to flashed back preloader and firmware of Tecno c9 phone and it was succesfull but still phone not on. when i read or identify info this is the massage i get.
Info read not done Erased/damaged phone?
full log.
Card found : S/N :
Chinese Miracle II
Operation : Fix Android Partitions
User selected Preloader file : preloader.bin
Operation : Init Preloader [ v1.58 ]
Supported HW by Preloader :
FlashID [0] CID : 150100513832334D42 , Name : Q823MB , Vendor : 15 , [SAMSUNG]
FlashID [1] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX]
FlashID [2] CID : 90014A484247346132 , Name : HBG4a2 , Vendor : 90 , [HYNIX]
FlashID [3] CID : 150100525831424D42 , Name : RX1BMB , Vendor : 15 , [SAMSUNG]
FlashID [4] CID : 15010051345A334D42 , Name : Q4Z3MB , Vendor : 15 , [SAMSUNG]
Wait for phone...
Phone found! [ 32 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x93
NAND Flash : NOT INSTALLED
eMMC Flash : 484A019065324741D54F0705A550428D
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x80000000
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , e2GA
[eMMC] : FLASH_CID : 90014A484147326505074FD58D4253A5
[eMMC] : FLASH_LEN : 0x00000003AB800000
[eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB]
DEV RID : 0xA922996A18CAFD009B069114C0C665FA
INT RAM : 0x00020000
EXT RAM : 0x80000000 [2 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
SecCfg Passed , 1799
BL : Storage supported by BootLoader!
Sending BootLoader ...
Preloader Sent , Init passed
PartTable Init Failed, Reflashing required!
All Done
Done!
Elapsed: 00:00:26
Reconnect Power/Cable!
Wait for phone...
Phone found! [ 32 ]
Sync...
Open port error , something went wrong!
Boot Error!
Operation Failed
Elapsed: 00:00:00
Scatter Load Ok , BaseBand : MT6753 , Project : mtk_android , Storage : EMMC
Files found : 24 , Set to Flash : 23
Ready to Flash!
======= Flash
Wait for phone...
Phone found! [ 15 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6753 , Project : mtk_android , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3619 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 1
Erase : 0x0000000000000000-0x00000003A3D80000
Flash Pre-Erase Done, time used : 00:00:00
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader.bin
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Done!
Use FLN Mode
Processing : Flash Write
Flash now : PGPT
Image Flash Ok
Flash now : PROINFO
Image Flash Ok
Flash now : NVRAM
Image Flash Ok
Flash now : PROTECT1
Image Flash Ok
Flash now : PROTECT2
Image Flash Ok
Flash now : LK
Image Flash Ok
Flash now : PARA
Image Flash Ok
Flash now : BOOT
Image Flash Ok
Flash now : RECOVERY
Image Flash Ok
Flash now : LOGO
Image Flash Ok
Flash now : EXPDB
Image Flash Ok
Flash now : SECCFG
Image Flash Ok
Flash now : OEMKEYSTORE
Image Flash Ok
Flash now : SECRO
Image Flash Ok
Flash now : KEYSTORE
Image Flash Ok
Flash now : TEE1
Image Flash Ok
Flash now : TEE2
Image Flash Ok
Flash now : FRP
Image Flash Ok
Flash now : NVDATA
Image Flash Ok
Flash now : METADATA
Image Flash Ok
Flash now : SYSTEM
Image Flash Ok
Flash now : CACHE
Image Flash Ok
Flash now : FLASHINFO
Image Flash Ok
Flash Write Done, time used : 00:07:07
Processing : Verify
Verify Passed : PGPT
Verify Passed : PROINFO
Verify Passed : NVRAM
Verify Passed : PROTECT1
Verify Passed : PROTECT2
Verify Passed : LK
Verify Passed : PARA
Verify Passed : BOOT
Verify Passed : RECOVERY
Verify Passed : LOGO
Verify Passed : EXPDB
Verify Passed : SECCFG
Verify Passed : OEMKEYSTORE
Verify Passed : SECRO
Verify Passed : KEYSTORE
Verify Passed : TEE1
Verify Passed : TEE2
Verify Passed : FRP
Verify Passed : NVDATA
Verify Passed : METADATA
Verify Passed : SYSTEM
Verify Passed : CACHE
Verify Passed : FLASHINFO
Data Verify Done, time used : 00:00:47
Update Mirror PMT
Update Done!
Update RomInfo done
Done!
Elapsed: 00:08:08
Operation : Check / Read Info [ v1.58 ]
Wait for phone...
Phone found! [ 32 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Done!
Elapsed: 00:00:06
Old 05-10-2018, 07:58   #2 (permalink)
2201's Avatar
Member: 2639338
Thanks Meter: 126
The Tecno C9 have two variants with different Cpu which are Mt6735 and Mt6753. As ur Logs can clearly tell u, Ur set has Mt6735 and u Loaded a scatter with Mt6753 so in such a way U will always kill customers phones and buy new ones. Always keep in mind that Logs are there for reasons so Keep reading them. Reflash ur phone with working firmware with Mt6735 Cpu and that should wake up ur phone
The Following User Says Thank You to 2201 For This Useful Post:
Old 05-10-2018, 11:51   #3 (permalink)
seyram's Avatar
Member: 1759904
Thanks Meter: 6
Bos i tried but i keep on getting the error and thats why i need your help please.
Old 05-11-2018, 11:01   #4 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,992
Hello,
Just find correct firmware and flash your phone.
Br.
Infinity Box Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Page generated in 0.25083 seconds with 7 queries
