03-24-2009, 10:44 | #1 (permalink) |
No Life Poster Join Date: Jan 2007 Location: udaipur, I N D I A Age: 37
Member: 422762 Status: Offline Sonork: 100.1593904 Thanks Meter: 973 | phone dead after flash with same firmware log here ==== log: [3/24/2009 2:03:03 PM] ==== COM8 [VCP0] selected module v2.78 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: EC76A5BD page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:007600A500BD [04200000] NOR chip is not installed Initialize Done Set baud ... 460800 Set baud Done Identification ... reading bootloader structure area... detecting bootloader structure... source data: page only identification#1 protocol ver: 04 ver. sw 1: K2_PCB04_GPRS_MT6228_S02.G30V01_01B05.BIN ver. sw 2: G30v01.01b05, 7186BF55 ffs offset/size: 02000000/02000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished Finished, time used: 36 sec Remove/Install battery now ! than i flash the phone with this file from support area K2_PCB04_GPRS_MT6228_S02.G30V01_01B05.BIN here is the log ==== log: [3/24/2009 2:16:49 PM] ==== COM8 [VCP0] selected module v2.78 Device: Autodetect 6228-6230 NAND Checking data, wait... Action: write NAND flash read mode: 01 write: Firmware skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs source data: page only identification#1 protocol ver: 04 ver. sw 1: K2_PCB04_GPRS_MT6228_S02.G30V01_01B05.BIN ver. sw 2: G30v01.01b05, 7186BF55 ffs offset/size: 02000000/02000000 id-page1 Ok end mark #2 found nfi area detection finished: Ok Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6228:8A02:8A02]... CPU: MT6228 high speed boot On chip: 0031:0000:0101 status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... version: 3.0207 loader: 3.748.0 NAND id: EC76A5BD page size: 200+10 pages/block: 20 bits i/o: 08 address cycles: 04 blocks: 1000 ram size: 00800000 NOR: 0000:000000000000 [00000000] NAND: 00EC:007600A500BD [04200000] NOR chip is not installed Initialize Done Set baud ... 460800 Set baud Done Identification ... reading bootloader structure area... detecting bootloader structure... source data: page only identification#1 protocol ver: 04 ver. sw 1: K2_PCB04_GPRS_MT6228_S02.G30V01_01B05.BIN ver. sw 2: G30v01.01b05, 7186BF55 ffs offset/size: 02000000/02000000 id-page1 Ok nfi area detection finished: Ok identification#1 structure: 2nd [enhanced] generation security area (code #1) is damaged, recalculation required identification#1 detection finished warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB.[K2_PCB04_GPRS_MT6228_S02.G30V01_01B05.BIN_AA40798E].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.27EADFDB._K2_P CB04_GPRS_MT6228_S02.G30V01_01B05.BIN_AA40798E_.rp l warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB.[K2_PCB04_GPRS_MT6228_S02.G30V01_01B05.BIN_AA40798E].rpl warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.27EADFDB._K2_PCB04_GPRS_MT6228_S02.G30V01_01B05. BIN_AA40798E_.rpl ==================== warning: unknown identification#1 structure: K2_PCB04_GPRS_MT6228_S02.G30V01_01B05.BIN_AA40798E error: Unknown firmware detected (v.2.78, database date: ), user action required: 1. download latest software from support area and try again 2. if no still luck follow the next procedure: - find good working phone with the same firmware: K2_PCB04_GPRS_MT6228_S02.G30V01_01B05.BIN - make "Read full flash" operation - send "system_log_..." file to support: [email protected] - send flash backup files to support: [email protected] - include in your e-mail full text from phone back label (phone name etc.) - be little bit patient and wait update ==================== You can flash phone now but can not finalize it. In most cases phone CAN NOT power-on. Do you want to continue anyway ? Identification Done Write ... write core area 1 of 2... write core area 2 of 2... Write Done Finished, time used: 640 sec Remove/Install battery now ! phone completely daed now, how to revive it |
help me plzzz k1/s dead after flash with same version | gagan_o5 | MSS Box II | 1 | 12-18-2008 04:04 |
Z250i Dead after flashing with R1F002 firmware. | faurionutz | Infinity-Box | 7 | 09-03-2008 22:10 |
Nec E228 dead after flashing with e313 firmware! | baushino | NEC | 5 | 03-06-2005 01:06 |
