08-11-2008, 15:27 | #3 (permalink) |
No Life Poster Join Date: Dec 2005 Location: NEAR YOU
Member: 205427 Status: Offline Sonork: 100.1580937 Thanks Meter: 1,162 | Dear Infinity, I too had a same problem with Motorola W200 CDMA but could not solve this by full flashing. Flashing ok and set ok too. Its the problem with new cdma sim cards. Here is the log for W200 >>>>> Device: Motorola-W200 Checking data, wait... Action: user code Connect... Phone must be Powered-On Connect Done Read phone info... software compiled: Jun 15 200619:18:11 software released: Jul 18 200516:00:00 software version: /cygdriv* model id: 108 MSM: F060 build id: KS3.6.10TEST ESN: 34C8BE48 Read phone info Done Verify access... user code: 0000 Verify access Done Decode data... user code: 0000 Decode data Done Finished, time used: 15 sec Remove/Install battery now ! Loading file v.02... w200_Main_TATA[1].2.2.07.B2M.bin loaded Loading file v.02... w200_Flex_FFN_A66_0111_036_Tata[1].B2F.bin loaded Loading file v.02... w200_LPH_A66_ASIA2_016_En_Hindi[1].B2P.bin loaded COM15 [Serial2] selected Device: Motorola-W200 Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... Connect Done Initialize... detecting chip[01]... flash: 8988C400010001:8988C400000000 flash: Intel I28F320C3B-T T 4Mb Initialize Done Set baud... 921600 Set baud Done Check parameters... flash: 8988C400010001:8988C400000000 reading [Motorola-W200_eeprom]... file saved: E:\Infinity\W200\backup_Motorola-W200_eeprom_20080807-143640.B2E.bin software version: 2.2.07. flex version: FFN_A66_0111_036 LP version: LPH_A66_ASIA2_016 hardware version: MOTOROLA_A66 ESN: 34C8BE48 Check parameters Done Check flash... Check flash Done Write... Area: Firmware flash: 8988C400010001:8988C400000000 Write: Firmware "safe mode" active Area: Flex/Customization flash: 8988C400010001:8988C400000000 Write: Flex/Customization Area: Language pack flash: 8988C400010001:8988C400000000 Write: Language pack Write Done Finished, time used: 438 sec Anyways thanks to Infinity Team >>>> |
08-11-2008, 18:30 | #4 (permalink) |
Registered User Join Date: Oct 2005
Member: 189506 Status: Offline Sonork: 100.1576871 Thanks Meter: 126 | man, these are no unlock flash files, so plz check ur operator's files.... like, if u use to tata sim card then flash it with 2.2.07 tata ruim flash files.........................ok |
08-11-2008, 18:32 | #5 (permalink) |
Member: 189506 Status: Offline Sonork: 100.1576871 Thanks Meter: 126 | for w355 , flash with Chinaunicom version..from support.............ur problem will be solved |
The Following User Says Thank You to bhogpurmail For This Useful Post: |
11-07-2008, 08:16 | #8 (permalink) |
Junior Member Join Date: Sep 2006
Member: 346271 Status: Offline Thanks Meter: 3 | Sur I Am try This Flash fils w200_Main_6.6.23 w200_Flex_FFN_A66_1011_022 w200_LPH_A66_ASIA1_020_En_Cn But error is COM62 [VCP0] selected Device: Motorola-W200 Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... Connect Done Initialize... detecting chip[01]... flash: 8988C400010001:8988C400000000 flash: Intel I28F320C3B-T T 4Mb Initialize Done Set baud... slowest Set baud Done Check parameters... flash: 8988C400010001:8988C400000000 reading [Motorola-W200_eeprom]... file saved: C:\Program Files\InfinityBox\QCModule\Motorola-W200_eeprom_20081107-124319.B2E.bin software version: 2.2.07. flex version: FFN_A66_0111_036 LP version: LPH_A66_ASIA2_016 hardware version: MOTOROLA_A66 ESN: 34C8DBD3 Check parameters Done Check flash... Check flash Done Write... Area: Firmware flash: 8988C400010001:8988C400000000 Write: Firmware "safe mode" active error: error# 000000FF error: flash write error: 00010000:00002000 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3B7C2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3B7C2E3B3B3BC42E3B3B3BFC2E3B3B3BFC2E3B3B3BFC 2E3B3B3BFC Write Fail Finished, time used: 87 sec Remove/Install battery now ! so whot i doo plz tall me |
03-21-2010, 09:02 | #12 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: lake city
Member: 386868 Status: Offline Thanks Meter: 125 | Quote: "wrong dm tool" and the error log is COM1 [VCP1] selected Device: Motorola-W355 Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Write: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... error: unexpected answer: error: can't load bootcode Connect Fail Finished, time used: 3 sec Remove/Install battery now ! kindly remove this fault to make all the users of infinity box able to unlock this phone............ thx in advance.l... sanjubhai. | |
How to Remove Phone locked - please contact service center | sameer525kk | Various CDMA/TDMA Cell Phones | 9 | 12-26-2009 08:38 |
c1000 phone locked -please contact service sentre | tuntai | Various CDMA/TDMA Cell Phones | 1 | 09-13-2009 07:41 |
W200 Phone Locked- Please Contact Service Center Not Solved With Infinity | jalesar | Infinity-Box | 3 | 04-02-2009 06:42 |
huwai c2900i phone locked please contact service centre | royal_electronics | Various CDMA/TDMA Cell Phones | 3 | 11-26-2008 18:14 |
w 200 phone locked please contact service provider | .:RAJESH:. | Infinity-Box | 3 | 08-18-2007 07:46 |
