12-11-2017, 13:35 | #1 (permalink) |
No Life Poster Join Date: May 2013 Location: Earth
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | Phone not boot when tried to flash phone info reads succesfully read flash succesfully but when tried to re-write shows this ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 33 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A305E0806B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A305E0806B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xE109B0628CD64D8FC2F4A7A21A21CF3D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : e118_lca , Storage : EMMC Setting : Flash Pre-Erase : Off ( Write Flash Only ) Setting : AFF verify : Enabled Setting : HW verify : Disabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3116 mV BL : [WARNING] : BatteryLevel LOW!!! SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_e118_lca.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0012 Update PMT by user request Operation Failed Elapsed: 00:00:31 Reconnect Power/Cable! Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first! Finish at : [12/11/2017 / 1:00:25 PM] Now phone not bootable a lot of phones which shows the error doesnt boot,now dead any solution to revive or help on how to check if possible or not before flash Last edited by nduka; 12-11-2017 at 13:41. |
12-11-2017, 14:46 | #3 (permalink) | |
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | Quote:
second i readed the firmware from the phone successfully READ 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 33 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A305E0806B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A305E0806B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xE109B0628CD64D8FC2F4A7A21A21CF3D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : samsung ProdName : j13gxx ProdModel : SM-J100H Device : j13g AndroidVer: 4.4.4 MTKxCPU : MT6572 MTKxPRJ : ALPS.JB3.MP.V1 [Read Ok] : preloader_e118_lca.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Read Ok] : cache.img [Read Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / e118_lca / EMMC Android Info saved HWConfig Info saved FW Size : 703 MiB Scatter saved to : C:\Users\AXXXX GSM\Desktop\MT6572__samsung__SM-J100H__j13g__4.4.4__ALPS.JB3.MP.V1\first third,i read info INFO Wait for phone... Phone found! [ 33 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164048601A305E0806B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048601A305E0806B [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB] DEV RID : 0xE109B0628CD64D8FC2F4A7A21A21CF3D INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Done! Elapsed: 00:00:08 Reconnect Power/Cable fourth,i tried to write same firmware back but not possible even tried to write another working one same What im trying to say is,if possible to know if phone will show this=Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!before flashing read my post very well before reply thanks Last edited by nduka; 12-11-2017 at 14:51. | |
12-11-2017, 15:56 | #4 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Hello, Quote:
12-11-2017, 20:58 | #5 (permalink) | |
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | Helo Mr Kiru... Check here http://forum.gsmhosting.com/vbb/f296.../#post12798405 Quote:
And why you always interest on battery area when it shows secure boot? http://forum.gsmhosting.com/vbb/f296.../#post12798353 Never you flash mtk phone without battery? If you don't,I have done many of them So in my case, that clone J100H sometimes I write without battery success I think this thread is meant for Pm or PS to reply back Last edited by nduka; 12-11-2017 at 21:06. | |
12-11-2017, 22:48 | #6 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | @nduka yes please, click to link that you have posted and see information about "read operation". it is very important to have well charged battery before write operation. also, what was the problem with phone when you have got it for repair ? please be noted that phone may have software problem and also hardware problem. f.e. phone after water damage can power-on well sometimes, but if you try to write flash phone can be damaged. do you know that ? |
12-12-2017, 07:21 | #7 (permalink) | |
Phone shows unfortunately system has stopped. Could that be hardware issue? Anyway what Im saying is if team would provide a check to know if phone will get this error Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first! before flash That's all Of course you knows how it feels when someone or client came with booting phone now going home with it dead Thanks | |
12-12-2017, 08:03 | #8 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Charge battery and make HW Test. If HW Test passes make NVRAM backup, erase phone including Preloader and flash with good firmware(better with original or read from good working phone). Br. Infinity Box Team. | |
12-12-2017, 11:48 | #9 (permalink) | ||
Member: 1943439 Status: Offline Sonork: 100.1669578 Thanks Meter: 214 | this is not matter of charging battery or not here is log for low battery flashed 100% ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 5 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 11010030303447393051E4532AC1B0E3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x11 , OEM : 0100 [eMMC] : FLASH_INF : [TOSHIBA] , 09G40 [eMMC] : FLASH_CID : 11010030303447393051E4532AC1B0E3 [eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000000EC000000 [eMMC] : FLASH_UCP : 3776 MiB [eMMC 4 GiB] DEV RID : 0xE109B062F70FC1F6AC9729A21635B817 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : rtech72_we_72_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3576 mV BL : [WARNING] : BatteryLevel LOW!!! BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000002900000-0x00000000E8680000 Flash Pre-Erase Done, time used : 00:00:00 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader_rtech72_we_72_kk.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash now : CACHE Image Flash Ok Flash now : USRDATA Image Flash Ok Flash Write Done, time used : 00:02:49 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Verify Passed : CACHE Verify Passed : USRDATA Data Verify Done, time used : 00:00:40 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:51 Reconnect Power/Cable! Quote:
and once it shows this,phone dead! Last edited by nduka; 12-12-2017 at 11:54. | ||
12-12-2017, 14:40 | #10 (permalink) | |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan
Member: 2138570 Status: Offline Sonork: 100.1611495 Thanks Meter: 301 | Quote:
this is 10000000% emmc problem dead emmc or read only now change emmc if possible or change board if possible | |
The Following User Says Thank You to Ismail khan1978 For This Useful Post: |
12-12-2017, 15:46 | #11 (permalink) |
No Life Poster Join Date: Jan 2016 Location: Gsm flashing
Member: 2521913 Status: Offline Thanks Meter: 251 | Bros go and buy nck box or avengers dongle is the best for mtk now cm2 will kill many people phone even in read info sorry for my advise it's very hot but is 100%%% true |
12-12-2017, 16:11 | #12 (permalink) | |
if in thousands of phones only 2 or 3 phones with faulty or currepted emmc are not alive by infinity this is not infinity's fault why are you blaming infinity box we know in every shop every mechanic has all boxes for china phones but i bet every one trust the one and only infinity box | |
12-12-2017, 19:11 | #13 (permalink) | |
I think so for emmc issue But my question is How can one knows the emmc condition or how to check info for emmc before flashing the phone? | |
12-12-2017, 19:15 | #14 (permalink) | |
Just that infinity is my best Last edited by nduka; 12-12-2017 at 19:23. | |
