Old 10-13-2008, 10:44   #1 (permalink)
dr.lolo's Avatar
Member: 309944
Sonork: 1628185
Thanks Meter: 40
the phone starts its self and icant format it
COM6 [VCP0] selected
Action: reset settings
Model: Autodetect 6205-6227 NOR
Checking data, wait...
19200 autodetect
Initializing[6205:8B00]...
CPU: MT6205
high speed boot enabled
Connecting, wait...
error: can't finalize test mode
repeat operation and HOLD phone "Power" button long time !
error: operation failed !
Finished, time used: 101 sec
Remove/Install battery now !
Old 10-13-2008, 10:57   #2 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 23,897
check the set without connecting VCC AND CNG connect the set with cable but not connect VCC AND GND cable and press format
Old 10-13-2008, 15:03   #3 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,051
Originally Posted by dr.lolo View Post
com6 [vcp0] selected
action: Reset settings
model: Autodetect 6205-6227 nor
checking data, wait...
Phone should be switched off !
Press and hold power button now !
19200 autodetect
initializing[6205:8b00]...
Cpu: Mt6205
connecting, wait...
error: Can't finalize test mode
repeat operation and hold phone "power" button long time !
Error: Operation failed !
remove/install battery now !
this error indicat flash chip, rehit chip and try ,or scrvice bord clin bord.
Old 10-13-2008, 21:42   #4 (permalink)
Member: 148515
Thanks Meter: 14,731
no, no, no guys!
please see that MCU type detected is 6205!
this is second MCU, which very rare need to be formated/flashed.
i advice to find first MCU pinout and continue to work with it.
if you sure that you need with second MCU- then you must keep power button pressed for about 40-50seconds.
do not release it even if phone powers On- this is normal.
first MCU starting, then will boot second
Help,how to fix the phone with SD damaged and SL=0000000? Smartmio MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 02-24-2010 10:26
nokia E61 phone start up failed and contact retailer please help asif_ae HWK 1 11-13-2008 04:41
Can not flash the phone. I got everything and up to last step!!! help please camel21 Nokia Base Band 5 ( BB-5 ) 0 07-15-2007 08:59
Samsung A300: stupid tone when the phone starts up sgha300 VLSI, Conexant, Skyworks and Old Models 0 02-22-2002 07:26
Page generated in 0.25621 seconds with 8 queries
