phone stuck after AV operation on CM2Mtk 1.33 Start at : [10/12/2015 / 10:06:15 AM] Operation : Remove Viruses [SmartAV] [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : A45J1 [eMMC] : FLASH_CID : FE014E50314A3534411205280199319B [eMMC] : FLASH_EXT : 00100000/00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SmartAV Init Ok! Scanning FileSystem now , please wait Scan Done, infected files found : 178 Removing infected files and scripts ... SmartAV Report : Removed 178 infected files! Making additional operations ... Special Op #1 : Clear Recovery Data Ok! Done! Done! Elapsed: 00:01:47 Reconnect Power/Cable! Finish at : [10/12/2015 / 10:08:03 AM] Start at : [10/12/2015 / 10:08:36 AM] Operation : Format FileSystem [ v1.33 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575|MT6577_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 00FE , OEM : 014E [eMMC] : FLASH_INF : A45J1 [eMMC] : FLASH_CID : FE014E50314A3534411205280199319B [eMMC] : FLASH_EXT : 00100000/00100000 [eMMC] : FLASH_LEN : 0x00000000E9800000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:14 Reconnect Power/Cable! Finish at : [10/12/2015 / 10:08:51 AM] |
write backup and do again smart av opration |
This is a test version & Advised - " Emergency requirement : If FW for target phone not available - MAKE FW READ BEFORE and mark it as "INFECTED_MTxxx_...." Have you its Full dump ? or flash the phone by original rom Br - srinibas |
