Old 10-12-2015, 07:14   #1 (permalink)
Member: 2217500
Sonork: 100.1597179
Thanks Meter: 290
phone stuck after AV operation on CM2Mtk 1.33
Start at : [10/12/2015 / 10:06:15 AM]
Operation : Remove Viruses [SmartAV] [ v1.33 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
BB_CPU_NM : [MediaTek] MT6575|MT6577_S00
Processing BROM stage
i2c Init : 00000000
SpeedSet : 0000
VChrgSet : 0x28 , BatStat : 0x02
WD Disable stat : 0x0000
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
DA Ver : MTK_AllInOne_DA_v7.1533.03
DA Stat : v3.2 on BBID : 0x84
DA Sent. Configure setting now ...
DA started successuflly
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 00FE , OEM : 014E
[eMMC] : FLASH_INF : A45J1
[eMMC] : FLASH_CID : FE014E50314A3534411205280199319B
[eMMC] : FLASH_EXT : 00100000/00100000
[eMMC] : FLASH_LEN : 0x00000000E9800000
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
SmartAV Init Ok!
Scanning FileSystem now , please wait
Scan Done, infected files found : 178
Removing infected files and scripts ...
SmartAV Report : Removed 178 infected files!
Making additional operations ...
Special Op #1 : Clear Recovery Data Ok!
Done!
Done!
Elapsed: 00:01:47
Reconnect Power/Cable!
Finish at : [10/12/2015 / 10:08:03 AM]
Start at : [10/12/2015 / 10:08:36 AM]
Operation : Format FileSystem [ v1.33 ]
Wait for phone...
Phone found! [ 19 ]
Sync...
Boot Info :
BB_CPU_ID : 6575
BB_CPU_HW : CB00
BB_CPU_SW : 8A00
BB_CPU_SB : E201
i2c Init : 00000000
SpeedSet : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Clear USERDATA
Clear Ok!
Clear CACHE
Clear Ok!
Done!
Elapsed: 00:00:14
Finish at : [10/12/2015 / 10:08:51 AM]
Old 10-12-2015, 07:21   #2 (permalink)
sneha's Avatar
Member: 327043
Sonork: 100.1587811
Thanks Meter: 1,441
write backup and do again smart av opration
Old 10-12-2015, 07:23   #3 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,303
This is a test version & Advised - " Emergency requirement : If FW for target phone not available - MAKE FW READ BEFORE and mark it as "INFECTED_MTxxx_...."
Have you its Full dump ? or flash the phone by original rom
Br - srinibas
The Following User Says Thank You to srinibas For This Useful Post:
Page generated in 0.21059 seconds with 7 queries
