Old 07-04-2009, 19:41   #1 (permalink)
Member: 594019
Thanks Meter: 46
Phones not detected by box
Hi;
Chinesse 6300 not detected by INFINITY BOX , But "read info" ok with spiderman cracked.
PINOUTS OK but still same
COM3 [VCP3] selected
module v2.84
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read/check detailed information
Boot ...
I already had this problem before with N95 2sim, and another chinesse 6300
What's a problem PLZ?
Old 07-04-2009, 21:07   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Are you sure that you have used correct COM port ?
Also, if you have used other software be sure that you have closed other software before try to connect phone with Infinity-Box.
Old 07-04-2009, 21:17   #3 (permalink)
moncef5's Avatar
Member: 163515
Thanks Meter: 23
Originally Posted by lucky_gsm View Post
hi;
chinesse 6300 not detected by infinity box , but "read info" ok with spiderman cracked.
Pinouts ok but still same
com3 [vcp3] selected
module v2.84
device: Autodetect 6205-6227 nor
checking data, wait...
Advanced flash detection enabled
action: Read/check detailed information
boot ...
Press and hold power button now !
I already had this problem before with n95 2sim, and another chinesse 6300
what's a problem plz?
try to uninstal infinity driver reboot uou pc install it again it well work well
Old 07-05-2009, 10:08   #4 (permalink)
Member: 594019
Thanks Meter: 46
RX light illuminates when I hold the power buton but nothing happens in the software.
I tried unistall COM and reinstall it but same, HOW to unistall all driver plz?
at this moment i need flash file for spiderman french langage pending to solve this problem.
And I ask you if i can use infinitys flash files with spiderman?
Thanx
Old 07-05-2009, 10:21   #5 (permalink)
Member: 594019
Thanks Meter: 46
I found the file in infinitys support, but I don't know if i can use it with spiderman cracked or not, plz help very urgent
Old 07-05-2009, 10:36   #6 (permalink)
Member: 708961
Thanks Meter: 8
file in infinitys support not working with spiderman crack .
Old 07-05-2009, 10:42   #7 (permalink)
Member: 594019
Thanks Meter: 46
Thanx bro, can you help to find flash file from spiderman crack?
Old 07-05-2009, 11:14   #8 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,603
but at the moment u r in wrong section..
check the China Phones Section or Spiderman Section.. add there to ur fw or search the flash file ur phone.. and let us to check for ur flash file...
b.r.
Old 07-05-2009, 14:23   #9 (permalink)
Member: 594019
Thanks Meter: 46
in the power supply, the boot does not maintain when i release power button, it return to 0.
any idea plz?
Old 07-08-2009, 17:47   #10 (permalink)
Member: 594019
Thanks Meter: 46
another Chinese phone that is not detected by the box, plz i want solve this problem very necessary. I killed one phone by spiderman crack,fortunately I've revived it to a friend by his infinity box , I don't want to repeat this experience.
I have this problem just with some chinese phones.
Question : Can UST PRO cause this problem when installed in same pc with infinity box and others box like Micro-box and Setool ? I have 5 box in 1 pc (Infinity, ufs, setool, ust pro, micro box)
Old 07-11-2009, 18:30   #11 (permalink)
Member: 594019
Thanks Meter: 46
Another 6300 rm-127 coming to me for flash, I tried but same problem, that's detect by spiderman crack, but not by Infinity box, plz Infinity team help, I'm sure that the problem is on software.
Old 07-11-2009, 19:12   #12 (permalink)
Member: 594019
Thanks Meter: 46
No answer???????????
Old 07-13-2009, 12:22   #13 (permalink)
Member: 594019
Thanks Meter: 46
Problem solved using UFS and infinity software
Old 07-13-2009, 21:30   #14 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
sorry, we did not reply because of weekend.
can you explane what was main problem and how did you solve it?
Old 07-14-2009, 08:53   #15 (permalink)
Member: 594019
Thanks Meter: 46
My infinity box, didn't detect any chinese phone which using PCB pinouts but work fine with others phones which connected by pinfinder, I tried with many phones but no success:
-I checked the voltage at pin1-8 is 5v
-I checked the pinouts with spiderman cracked, all was ok
-I installed infinity box alone in another pc.
-I tried with old version of chinese miracle module
-I used another cable...
but same problem
-After this i connected infinity box and ufs.
-I runned direct com for changing ufs to com port
-I selected com port (of ufs) in interface
and it worked perfectly
In your opinion what's the problem in my infinity box? knowing that working fine before
Multi box not detected by pc talatmehmood Multi-Box 3 12-14-2008 14:04
new pcb my100x not detected by box llcoolr Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 3 11-15-2008 12:23
LG Workshop 1.92SC, phone not read by box? stinky180 VygisToolbox 4 08-19-2008 21:36
I-Phone Not Detected by PC dannyogolo iPhone 2 / iPhone 3G / iPhone 3GS 0 02-08-2008 13:25
Page generated in 0.26358 seconds with 9 queries
