Old 06-13-2011, 15:29   #1 (permalink)
Crazy Poster
Member: 848758
Thanks Meter: 11
pin finder in (infinity combo plus)
hello infinity team
i buy anew box combo edition
but i face aproblem whith finder can not find any
pinout <>>>>i try whith cpu 6225 but no result
and show this message
software version: 1.26
platform: MT: MT62xx (autodetect)
cable type: 1x12 (L12C)
mode: Slow
Fast
searching adapter at COM11 (115200)...
too many retries
adapter found, version: 4000
Loading platforms configuration...
Initializing platforms...
Press and HOLD phone Power button now !
pins: 12, plain
power/activation cycles: 1/7
power-off delay: 20
start Rx/Tx: 1/1
detecting pins...
too many retries
too many retries
connection w/adapter lost during set Tx as pin 3
failed to detect pins
time required: 4 sec
too many retries
Trying to Power-On...
too many retries
Power is Off
too many retries
please infinity team slove my problem
or return my box to reselar to replace
thankyou
note(when i conect red waire to mobile the red light in box off )
Old 06-13-2011, 20:58   #2 (permalink)
Temporary banned !!
Member: 555091
Thanks Meter: 10
same problem pls help
Old 06-13-2011, 21:01   #3 (permalink)
Member: 148515
Thanks Meter: 8,530
hello!
please post search log of L3A connector in slow mode.
Do not connect phone!
Old 06-14-2011, 12:25   #4 (permalink)
amn32's Avatar
Member: 569925
Sonork: 100.1624057
Thanks Meter: 5,800
First of all plz. check phones, shortage and then connect phone to finder.
Old 06-14-2011, 12:47   #5 (permalink)
Crazy Poster
Member: 848758
Thanks Meter: 11
hello!
thankyou infinityhelp
this is alog for l3a
cable type: HF 3 pin (L3A)
mode: Slow
Fast
too many retries
pins: 3, plain
power-off delay: 20
start Rx/Tx: 1/1
detecting pins...
Power is On
Old 06-14-2011, 12:51   #6 (permalink)
Crazy Poster
Member: 848758
Thanks Meter: 11
i check in agood phone just i want to make backup flash file>>>>
pin finder not work and red light in box off when i connect red cable to phone
Old 06-14-2011, 13:29   #7 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
Thanks Meter: 348
Dear i face same problem in my box but i do some tricks.
when dialog box coming press power on button click ok.
and see the little box running its' mean pin-finder search pin-out by cable.
u select 10x1 cable and u see 10 little box appear and one by one color change
now when 3 box go then you keep and press phone power on button.
do it hope helpful.
The Following User Says Thank You to net.tarik For This Useful Post:
Old 06-14-2011, 13:57   #8 (permalink)
Crazy Poster
Member: 848758
Thanks Meter: 11
do it hope helpful.
thankyou but same problem light off when i connect
the red cable to phone
Old 06-14-2011, 14:30   #9 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
Thanks Meter: 348
check volt in pin-finder phone power supply cable when pin-finder active 5+
also check pin-finder phone power supply cable it's sort.
Old 06-14-2011, 15:17   #10 (permalink)
Crazy Poster
Member: 848758
Thanks Meter: 11
My problem sloved
HELLO IFINITY TEAM
AFTER HARD WORK I FOUND PROBLEM IN THE TOW CABEL
RED AND BLACK (GO TO CONECTOR BATTERY TO PHONE )
I OPEN THE MAIN CABLE AND EXCHANGE Between RED AND BLACK CABEL
AND THE PIN FINDER WORK OK
THIS IS LOG
mode: Slow
Fast
too many retries
pins: 12, plain
power-off delay: 20
start Rx/Tx: 1/1
detecting pins...
19200 fixed
CPU: MT6225
result: Rx:7 Tx:6
time required: 39 sec
Power is On
Old 06-14-2011, 21:17   #11 (permalink)
Member: 148515
Thanks Meter: 8,530
hello!
sorry for late answer.
Yes, if without phone it gives No errors-
then you must search for problem in power lines.
Measuring output voltage is all what is needed for detecting problem
Old 06-18-2011, 00:42   #12 (permalink)
Member: 1216581
Sonork: btcoolmi
Thanks Meter: 3
PLEASE IT IS LONG TIME AGO I HAVE COMBO BOX BUT NEVER I UNLOCK CHINESS PHONE OR RESET CODE? PINFINDER NO WORK, can HELP ME?
Old 06-22-2011, 15:47   #13 (permalink)
Member: 148515
Thanks Meter: 8,530
hello!
sure, we can help. please follow pinfinder user manual step by step.
let us know at what point you get problem, show us pinfinder log
Old 07-05-2011, 10:59   #14 (permalink)
Member: 1216581
Sonork: btcoolmi
Thanks Meter: 3
HOW I CAN WORK WITH THIS PINFINDER?????? I PAY 1YEAR AGO BUT NOTHING WORK AND DETECT PIN EVERY TIME THE RESULT FOLLOW:
cable type: 1x5 (L5A)
mode: Slow
Fast
searching adapter at COM16 (115200)...
too many retries
pins: 5, plain
power-off delay: 20
start Rx/Tx: 1/1
detecting pins...
time required: 13 sec
Power is On
PLEASE TEAM CAN TO YOU TELL ME EXALTLY WHAT ABOUT PINFINDER BECAUSE NO WORK????? i have many password for chiness phone 2sim but nothing nothing work??????
Old 07-05-2011, 21:27   #15 (permalink)
Member: 148515
Thanks Meter: 8,530
hello!
5 pin phones usually have test points.
In 50% of cases no tx/rx in system connector
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
PIC for lock 2 What pin for clock ??? ondenuove Nokia Hardware & Hardware Repair 5 10-28-1999 08:49
Pin Code Verdonn Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 10-23-1999 15:35
New menu item in 5110 GeoMan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 09-23-1999 20:24
Lock 2 in nokia 51xx/61xx Pablo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-31-1999 04:35
Powered by Searchlight © 2017 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.46430 seconds with 8 queries
