09-18-2008, 19:24 | #1 (permalink) |
Registered User Join Date: Sep 2006
Member: 347872 Status: Offline Thanks Meter: 5 | w150i error write. COM4 [VCP1] selected Device: Motorola-W150i Checking data, wait... connection mode: Standard connection Action: Flash write "safe mode" enabled Write: Firmware Write: Flex/Customization Skip: Language pack Skip: FFS/File system Skip: Eeprom Connect... Phone must be Powered-Off Connecting, wait... Press and HOLD Power button now ! Connecting, wait... Connect Done Initialize... detecting chip[01]... flash: 8988C400010001:8988C400000000 flash: Intel I28F320C3B-T T 4Mb Initialize Done Set baud... slowest Set baud Done Check parameters... flash: 8988C400010001:8988C400000000 reading [Motorola-W150i_eeprom]... file saved: D:\KUMPULAN DVD\INFINITI\FRIMWARE INFI\motorola\frimware motorola w 150 i\cina\backup_Motorola-W150i_eeprom_20080919-021958.B2E.bin software version: Ô flex version: FFN_A86_0514_019 LP version: LPH_A86_ASIA7_009 Probably wrong model selected. Are you sure you want to continue ? ESN: 00000000 Check parameters Done Check flash... Check flash Done Write... Area: Firmware flash: 8988C400010001:8988C400000000 Write: Firmware "safe mode" active error: wrong answer[0D] error: flash write error: 00010000:00002000 error: wrong answer[3B] error: flash write error: 00010000:00002000 error: wrong answer[3B] error: flash write error: 00010000:00002000 error: wrong answer[3B] error: flash write error: 00010000:00002000 Write Fail Finished, time used: 108 sec Remove/Install battery now ! What is the problem??hardware or Flash file not match with this phone?? |
ERROR write eeprom SAVY,Philips. | sjakie | Various | 0 | 01-22-2000 22:27 |
