11-24-2008, 18:35 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! First lets make sure that this phone is based on MT62xx MCU. you can do this either by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
11-25-2008, 18:48 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx if system connector will not show needed voltages- you must examinate same way all available test points. |
12-09-2008, 19:20 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! post your 6110 navigator PCB picture, we with a help of forum members we will try to help to locate Tx/rx points on PCB. please make sure that you hold photo camera far enough to get picture in sharp focus |
6110 chinese pin out | jerieves | Infinity-Box | 9 | 10-30-2008 06:53 |
PIN OUT CECT Y767 DUAL SIM 24 pin | andr3_jc | Infinity-Box | 4 | 09-14-2008 22:15 |
chinese nokia 5300 1x12 pin connecter---pin out | vineet thapar | Infinity-Box | 2 | 01-10-2008 19:41 |
KISEN P83 pin out 1x18 pin connecter | vineet thapar | Infinity-Box | 5 | 12-28-2007 21:44 |
LG cable i made 26 pins but i need the other pin outs | jorus | LG | 0 | 10-14-2003 09:43 |
