03-12-2008, 17:17 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Dear Friend, There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en |
03-13-2008, 18:48 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,535 | hello! we dont have pinouts for this models in our database. i would advice to start from opening phone and checking marked test points on PCB. also, check if phones are MT62xx based phones. If they are supported by infinity software, but no test points then is 3 options available. 1. wait for someone's help 2. use our new product Pinout Finder 3. search for pinout using multimeter (this method is described in our FAQ section) |
03-27-2008, 17:05 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,228 | Hello kiran ! I have spend several hours and now special instruction for your phone is ready, please, read it very carefully: There are different "Chinese" phones with the same name but absolutely different hardware exist on market. Example: exist at least 30 "Chinese" phones with name "N95", at least 20 models "N73" etc. but all models has difference in hardware, different bottom connectors, different pinouts and and has different firmware, so it's impossible to give any advice about phone pinout only by phone name. So we recommend you to include the next information in your request regarding pinout: 1. detailed description of model: brand name, model name, complete text from phone back label, any other marks that you can find on phone cover 2. phone CPU chip name 3. phone PCB photo (Rx/Tx/Gnd test-points may exist on phone PCB) 4. attach phone photo 5. attach phone bottom connector photo 6. include information about Gnd and Charge pins on phone bottom connector After you have this information prepared, you can find pinout by yourself more easy than before, just check the next detailed description how to get pinout for your model: 1. use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 2. if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle\ 3. if not helps, please read: http:///vbb/showpo...36&postcount=7 4. if not helps, please read: http:///vbb/showthread.php?t=433447 Universal solution for pinout detection: http://www.infinity-box.biz/index.ph...infinder&lg=en |
CECT U8800 chinese i need corect pin out please | yane | Chinese Cocktail | 10 | 08-18-2009 09:48 |
Nec N901 Pin Out Please | taleb_nazari | Infinity-Box | 3 | 04-11-2008 11:33 |
3G Toshiba/Sanyo cable pin-outs please!!! | 3stanGsm | FuriousGold | 6 | 09-06-2006 04:20 |
3G Toshiba/Sanyo cable pin-outs please!!! | 3stanGsm | VygisToolbox | 1 | 09-05-2006 21:46 |
