05-08-2008, 11:11 | #1 (permalink) |
Registered User Join Date: Feb 2004 Location: MERSIN, TURKEY
Member: 55026 Status: Offline Thanks Meter: 53 | PINFINDER 1.09 can not find pins for NOKLA 6500s! regards. software version: 1.09 cable type: 1x8 (L8A) platform: MT62xx (autodetect) searching adapter at COM4... adapter found, version: 2000 pins: 8, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... failed to detect pins time required: 35 sec Power Off ! |
05-08-2008, 11:29 | #4 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | with usb cable I read these information from phone but can not find PIN OUTs for flashing.. Action: read information Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched ON ! Connecting, wait... Phone detected, wait... Hardware version: MT6226, E02 Hardware version: NEOTEL26_06B_HW Software version: 650032_500_V0031" Software date: 2005.04.12 Barcode: K1M1231710170018 SP 10 imei: 354101000003929 Finished, time used: 5 sec Power off phone now ! IkaMazini@ thank you for your interesting but phone has 8 pin conector 1x8 |
05-08-2008, 20:19 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! usb cable use different port to read this information. Might be that this phone doesnt hold tx/rx in system connector. I would advice to open phone and check marked test points |
05-09-2008, 14:40 | #7 (permalink) | |
Member: 55026 Status: Offline Thanks Meter: 53 | Quote:
I opened the phone and searched everywhere but there is no any test points, I have in hand many phones, please share your infos for that topic, waiting help! best regards.. | |
05-09-2008, 19:29 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets do this way: connect L8A cable to phone and measure voltages on all phone pins, on powered On phone. this is easy to do by setting needle to big DB26 connector. keep one multimeter probe on some grounded phone part, and antohre probe set to all pins on by one Pins are marked in DB26 connector, so you need to check pins from 1 to 8. if you see on pins voltages 2,7-2,9 volts- they will be data pins. |
05-13-2008, 15:38 | #9 (permalink) |
Member: 55026 Status: Offline Thanks Meter: 53 | MATE! sure I tested this way too.. I got only on one pins possible volstage.. all others under 1.5 vols.. really difficult case, that's why asking you..maybe somene has fount it and want to share with us.. |
05-14-2008, 15:04 | #12 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! this just can't be... CHeck all places on PCB, sometimes they are hidden under IMEI sticker or LCD. also you can try to change default Pinfinder values to make delay between pulses greater and also increase pulse duration |
Pinfinder can not find pin spreadtrum cpu | Shohel_sst | Infinity-Box | 6 | 06-02-2011 20:34 |
i can not find the pin out for ufo digital mobile | uburo22 | Infinity-Box | 3 | 11-22-2008 16:34 |
Pinfinder show me error during finding pin | skd_123 | Infinity-Box | 1 | 05-04-2008 15:20 |
Can not find win pin finder adapter wit this model | djamel852 | Infinity-Box | 1 | 03-12-2008 16:46 |
C:\Wintesla\ can not find flasfiles for DCT3 | powerman | Twisterflasher | 10 | 10-24-2004 18:17 |
