03-09-2008, 06:59 | #1 (permalink) |
Junior Member Join Date: Sep 2007
Member: 597803 Status: Offline Thanks Meter: 3 | Pinfinder adapter can't power on the phone maybe pinfinder damaged ???? IN RESUME (alimentaion does not work with pinfinder adapter) is there any solution or must I return it to the reseller ? THANKS |
The Following User Says Thank You to hastenslowly For This Useful Post: |
03-10-2008, 11:25 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! some PC ports do not give enough power to power On phone completely. But this power is enough for finding pinout and flashing phone. So dont worry, just follow user manual and you get success in pinout search. also please check if you using Battery positive terminal, not Btemp contact. THis is most common problem when phone not powering on |
11-20-2009, 16:51 | #3 (permalink) |
Freak Poster Join Date: Sep 2009 Location: www.telefony-nawigacje.pl
Member: 1122479 Status: Offline Thanks Meter: 22 | i have the same problem...4,96v and can't detect any phone,pinout etc what's wrong?i have brand new equipment and also short diod on infinitybox what's next? |
The Following User Says Thank You to seba6250 For This Useful Post: |
11-20-2009, 21:20 | #6 (permalink) |
Member: 1122479 Status: Offline Thanks Meter: 22 | good wuestion i will check it but it is strange problem for me, before i short diod i had 3,7v , now(after short diod) i have 4,96 and its little???:/ |
11-21-2009, 11:51 | #7 (permalink) |
Member: 1122479 Status: Offline Thanks Meter: 22 | ok so i checked that V and on usb cable i had 4,9v ,i shorted that usb cable to 10cm and voltage automaticaly change to 5v!! but when i connect adapter to infinity and check voltage on -crocodile- the voltage is 4,9:/ please help me |
11-22-2009, 00:03 | #8 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
this voltage is enough for success pinout search as long as you are able to power On phone which is sourced from pinfinder. and another main rule: you must check that your phone is MT62xx CPU based. and the third: some phones just dont keep tx/rx in system connector and you anyway have to disassemble phone and search for test points | |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
11-24-2009, 20:33 | #9 (permalink) |
Member: 1122479 Status: Offline Thanks Meter: 22 | there is necessary connected tx/tx/ to power on the phone with connected only crocodile? |
01-12-2010, 13:12 | #11 (permalink) |
Insane Poster Join Date: Nov 2008 Location: algeria Age: 44
Member: 901024 Status: Offline Thanks Meter: 61 | hi brothers i've the same problem i can finf tx and rx pins with my pin finder i can flash i can do eny thing but when i would like to rebuild imei i can't make the phone on ?? eny sollution ?? or i must open my infinity and pin finder to make the jump ?? N.B : i've a labtop as source |
The Following User Says Thank You to aminem_gsm For This Useful Post: |
01-12-2010, 20:48 | #12 (permalink) | |
no need to open pinfinder. Just open mian infinity box and shortcut that diode. It is usless component, its limiting output voltage from 5 volt to 4,2 | |
The Following 3 Users Say Thank You to InfinityHelp For This Useful Post: |
11-16-2010, 13:44 | #14 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: UNLOCKING IN GENERAL:) Age: 51
Member: 196126 Status: Offline Thanks Meter: 80 | Short which diode Quote:
It happened a few weeks ago before its been workin wellBR | |
If box can't power on the phone it's porblem ?? | utuh | CPF-BOX Ⅱ | 1 | 04-07-2009 06:08 |
u880 press power on the phone auto on n off | chris2007 | FuriousGold | 4 | 10-03-2007 14:01 |
R225 problem of please wait when u power on the phone | GSM MIND | SYSOL Platform | 1 | 07-04-2006 12:25 |
broplem with 6610 ..... power on the phone done but???? | amir-cairo | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 01-05-2004 23:06 |
Can't power on the phone when flashing it. Why ? | blablabla | x1x to x45/x50 | 2 | 08-09-2000 22:24 |
