Old 09-01-2009, 12:04   #1 (permalink)
mg70brz's Avatar
Member: 18726
Thanks Meter: 26
Exclamation pinfinder not communicate with Nokia clone chinese !!
i have infinity box plus + pinfinder installed and work correct from major of chinese phones but has problematic with Nokia clone as > E71 , E71tv, N89, N88, etc, but its not communicate, i try many times with the correct cable and run the pinfinder and appears the rx and tx pins but the phone only startup for 1 second and off,and repeat this during the try at the moment when the expire time for try to communicate, its appears a low voltage because the phones is power on and its Ok if used with battery.
Old 09-02-2009, 11:42   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
three is two things to do to get better pifninder work:
always set "silent" mode on phone before work.
this can be done by pressing and holding "#" button.
china phones startup sound takes arround 0,5-1A, so this current can not be provided by USB port of you PC.
second thing: main infinity box has diode which is limiting output power from 5volt to 4,3v.
it must be desoldered and shortcutted. Extra power which we get after that will make phones powerable.
procedure is described in pinfindr user manual "trubleshooting" section.
d ultimate unlocker could not communicating with server rajendrakumar D-Unlock Suite 6 07-07-2009 00:10
T191 serial data cable; PC not communicating with phone Phil_Thommo Motorola ODM 2 10-01-2006 18:25
Motorola t191 not communicates with PC prabu001 Motorola Hardware Repair 0 12-09-2005 12:06
SL55 unlock code please (the phone not communicate with computer) qwerthj Phone Unlocking Codes & Maps 0 06-23-2004 00:34
Page generated in 0.13638 seconds with 9 queries
