Pinfinder Not Detcted Ztc Zt 580 Model SIR what is the problem in my pinfinder, this is the log software version: 1.10 cable type: 1x10 (L10A) platform: MT62xx (autodetect) searching adapter at COM6... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed 19200 fixed failed to detect pins time required: 45 sec Power Off ! |
hello! is this MT62xx based phone? |
yes sir it is MT62XX base phone |
something like rx tx mark on the pcb? some phone got rx tx on pcb. thanks |
sir i chake pcb but nothing rx,tx, gnd |
hello! they can be not marked as "tx", "rx" do you have some dots on PCB? |
yes sir near battery connector some dots?, |
hello! there is your tx/rx pins. you can detect which pins exactly by measuring voltage on them pins with voltage 2,7-2,9 volts are tx/rx |
sir, i am using same mobile some time it display restricted area how to solve it plz. help me |
hello! which phone model? can you explane little bit more what problem do you facing |
