Old 06-09-2008, 20:11   #1 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
Pinfinder Not Detcted Ztc Zt 580 Model
SIR
what is the problem in my pinfinder, this is the log
software version: 1.10
cable type: 1x10 (L10A)
platform: MT62xx (autodetect)
searching adapter at COM6...
adapter found, version: 2000
pins: 10, plain
power cycles: 1
activation cycles: 7
power-off delay: 20
start Rx/Tx: 1/1
Loading configuration...
Initializing...
Press and HOLD phone Power button now !
detecting pins...
19200 fixed
19200 fixed
failed to detect pins
time required: 45 sec
Power Off !
Old 06-09-2008, 21:16   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
is this MT62xx based phone?
Old 06-09-2008, 22:40   #3 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
yes sir it is MT62XX base phone
Old 06-10-2008, 00:55   #4 (permalink)
Member: 39948
Thanks Meter: 68
are you check the phone pcb??
something like rx tx mark on the pcb? some phone got rx tx on pcb.
thanks
Old 06-10-2008, 06:41   #5 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
sir i chake pcb but nothing rx,tx, gnd
Old 06-10-2008, 12:00   #6 (permalink)
Member: 148515
hello!
they can be not marked as "tx", "rx"
do you have some dots on PCB?
Old 06-10-2008, 13:33   #7 (permalink)
Member: 771937
Sonork: 100.1605717
Thanks Meter: 1,052
yes sir near battery connector some dots?,
Old 06-11-2008, 14:21   #8 (permalink)
Member: 148515
hello!
there is your tx/rx pins.
you can detect which pins exactly by measuring voltage on them
pins with voltage 2,7-2,9 volts are tx/rx
Old 10-18-2008, 07:12   #9 (permalink)
Member: 878773
Sonork: prashant
sir, i am using same mobile some time it display restricted area how to solve it plz. help me
Old 10-18-2008, 15:33   #10 (permalink)
Member: 148515
hello!
which phone model? can you explane little bit more what problem do you facing
Old 10-21-2008, 05:15   #11 (permalink)
Member: 878773
Sonork: prashant
hello!
sir, It's ZTC ZT 580 - PHILIPS Model. when i use the same SIM card in other mobile it's work. but same SIM or other SIM i insert it will give message "Restricted Area", i m using IDEA card but it's shows birala At & T tower. plz help me
ZTC ZT 8380 not supported... rajumobile Infinity-Box 14 06-11-2009 05:29
Pinfinder Not Detcted Simoco Sm-999 Model debmobile Infinity-Box 3 06-21-2008 08:18
Pinfinder Not Detcted THIS SET?????? debmobile Infinity-Box 3 06-13-2008 20:06
zt 580 pinout plsssssssssss .:anbu:. Infinity-Box 1 01-12-2008 23:15
Page generated in 0.31783 seconds with 9 queries
