Old 10-22-2008, 14:50   #1 (permalink)
Registered User
Member: 702331
Thanks Meter: 61
Need flash file
SIR I WANT THIS FLASH
HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_67.BIN
BUT IN SUPPORT AREA I AM FOUND THIS IS IT SAME
KCM25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08 _12__16m_En_Ru_Fr_Es_De_Id_Th_Vn_Tr_Farsi_Pt_Ar.B0 M.bin
Old 10-22-2008, 16:01   #2 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
no, they are not same.
however you can try any file you wish after you save original backup from your phone for emergency case.
Old 10-29-2008, 08:41   #3 (permalink)
Registered User
Member: 702331
Thanks Meter: 61
i am read in anthor same set but file name like this
id.0E098CDD.[S100_D7_PCB01_GPRS_MT6226_S01.FM_SUM_GG2052.BIN_6C ADD9D5].rpl but
here is the log COM3 [VCP0] selected
module v2.66
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read NOR flash
Boot...
19200 fixed
Connecting, wait...
Initializing[6225:8A03:8A00]...
CPU: MT6225
high speed boot enabled
chip: 0001:8C03:000B
boot step size: 0400
Release Power button now !
Boot Done
Initialize...
flash: 98004900000002:18E59F00000000
flash: Toshiba AMD/Fujitsu std [T 0008x002000 00FFx010000] 16Mb
detecting chip #01 in region #00...
number of flash chip/regions detected: 02/01
Initialize Done
Set baud...
115200
Set baud Done
Initialize bootcode...
Initialize bootcode Done
Check firmware integrity...
device parameters autodetection in progress..
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
detect device identification#1...
detection phase #1...
detect device identification#1 finished
identification#1 structure: 2nd [standard] generation
identification#1 protocol ver: 04
ver. sw1: HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_67.BIN
ver. sw2: MAUI.GEMINI.W08.12.67, 00000000
ffs offset/size: 00E00000/00200000
detect device identification#2...
warning: optional information is not found,
if phone works well just ignore this warning
detect device identification#2 finished
detecting eeprom/ffs area in 1 chip(s)...
standard eeprom/ffs offset detected: 00E00000
checking area[00000000]: 00000000-00FFFFFF...
eeprom/ffs found near: 00E00000
detecting eeprom/ffs size...
eeprom/ffs size: 00200000
ffs chip: 00
eeprom/ffs area: 00000000:00E00000-00FFFFFF
Check firmware integrity Done
Check firmware content...
Check firmware content Done
Backup required data...
reading: flash[HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_67.BIN]...
file saved: C:\Program Files\InfinityBox\Flashes\id.0E098CDD.[S100_D7_PCB01_GPRS_MT6226_S01.FM_SUM_GG2052.BIN_6C ADD9D5].rpl
Finished, time used: 1914 sec
Remove/Install battery now !
Old 10-29-2008, 11:18   #4 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
Try to flash your first phone with flash[HEXING25_GEMINI_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_ W08_12_67.BIN] file.
Also, please, send this flash file to [email protected]
Old 10-30-2008, 08:33   #5 (permalink)
Registered User
Member: 702331
Thanks Meter: 61
which file i select may this \id.0E098CDD.[S100_D7_PCB01_GPRS_MT6226_S01.FM_SUM_GG2052.BIN_6C ADD9D5].rpl
NKTEL A200 flash file in Spider man box need flash file? >>.123.<< SpiderMan 15 11-12-2010 16:12
E66 nokia need flash file no flash file in support lilong_lee Infinity-Box 11 02-07-2010 01:51
!!!!! Needed, flash file for 8120 02 sfi file !!! stemo FuriousGold 2 03-11-2009 20:08
L7i need flash file and boot file aukonline Smart-Clip 3 03-10-2009 11:15
i need flash file and database file for t190 v 1.71 becuase nanana Motorola ODM 0 08-17-2002 11:37
Page generated in 0.19193 seconds with 9 queries
