02-06-2008, 03:51 | #4 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! looks like very rare model A960 with 18pin connector. are you sure it is MT processor based? Also have you opened phone and looked for marked test points on PCB? |
02-07-2008, 23:20 | #8 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! in this case as long as nobody helping with pinout i would advice you to find it by yourself. just measure voltage on all pins and then reffer to this tutorial: http:///vbb/attach...7&d=1187384324 this is easy 10min job |
02-08-2008, 14:33 | #10 (permalink) |
No Life Poster Join Date: Jul 2006
Member: 308296 Status: Offline Thanks Meter: 152 | sir i m find the pinout but when i m format the set software says new finware detected after ok show this error Flash erease error:00EC0000.Retry? pinout is =1 !!!!!!!!!!!!!!!!!!! 18 18pin conector 8pin= gnd 13pin =rx 14pin-tx sir plz give me the solution thanks inadvance |
02-09-2008, 23:33 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,531 | hello! first of all make full backup of phone firmware for emergecy case. after this make format FFS in safe mode later, if will not help- make FFS format in complete mode, using this "standart address" |
02-10-2008, 07:34 | #14 (permalink) |
Member: 308296 Status: Offline Thanks Meter: 152 | sorry sir i m asking a ouestion i m where from select" standart address" option sir i m try to format the set safe or complete but set always accpett only complete format and alwys give this message flash erease error 00EC0000 sir if possible plz help me for standerd addrees with picture Thanks in advance |
m7500 unlock?? any pinouts for rj45 to phone?? | GospoPL | UST Pro II | 0 | 03-26-2009 17:56 |
Need help I need pinout for this chinese phone | cayton_l | Infinity-Box | 9 | 12-03-2008 19:22 |
neede pinout for lovme china phone | unlocker87 | Chinese Models & Cloned Phones | 0 | 11-04-2008 23:49 |
Here you can find reall pinouts for new Motorola phones (V66,V60...) | VictorGSM | Motorola P2k | 2 | 11-27-2001 22:07 |
