Old 01-30-2010, 09:54   #1 (permalink)
ziadi_alaeddin's Avatar
Member: 650956
Sonork: doki-doc gsm
Thanks Meter: 72
pinout Anycool t808 20 pin
Gnd : 1, 2, 3,
RX : 8
Tx : 10
COM4 [VCP0] selected
module v3.07
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: reset settings ("format ffs")
ffs/eeprom backup enabled, it may takes several minutes !
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6225:8A03:8A00]...
CPU: MT6225
high speed boot On
chip: 0001:4E03:0000
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: EC257E25082501:18E59F00000000
flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
device parameters detection in progress...
it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: 2nd [standard] generation
TCL-ID is absent
rom info detection finished
New firmware detected (v.3.07, database date: 16.01.2010):
E880_KDI1OVF10_E880_GPRS_MT6225_S00.01_9.BIN
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
rom info ver: 04
sw version: E880_KDI1OVF10_E880_GPRS_MT6225_S00.01_9.BIN
project-id: E880_KDI1OVF10.01.9, 00000000
code offset: 00000000
ffs offset/size [01]: 00E00000/001FF000
TCL-ID is absent
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
standard ffs/eeprom offset confirmed: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
reading: E880_KDI1OVF10_E880_GPRS_MT6225_S00.01_9__ffs...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\E880_KDI1OVF10_E8 80_GPRS_MT6225_S00.01_9__ffs_20100130-095330.B0E.bin
Backup required data Done
====> Patch required data ...
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
Finished, time used: 2 min 27 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
The Following 2 Users Say Thank You to ziadi_alaeddin For This Useful Post:
Old 11-20-2010, 12:48   #2 (permalink)
Member: 568071
hi ty for help but...
gnd 1 2 3
rx 10
tx 8
I NEED PINOUT N81 mt62xx 20 PIN bsat Infinity-Box 4 04-20-2009 23:06
Anycool T808 12 Pins dvb_gsm Infinity-Box 2 03-08-2009 23:23
anycool t808 cable without pin finder... ZIYAAD STRYKER Infinity-Box 3 02-03-2009 22:29
Anycool T808 pinout need help! CLIFFORD25502 Multi-Box 5 09-08-2008 03:30
Problem with Anycool T808 and Pin Out Bela_Zmija Infinity-Box 11 06-17-2008 10:35
Page generated in 0.25089 seconds with 8 queries
