pinout for chinese " I love " any boady know this phone plz or its pinout , have I LOVE mentioned in front . thx in advance |
its better to post pin connector type and upload some pictures and also open phone see witch CPU on it and try to find pins with pinfinder if you still fail to find then check RX tX on pcb is still not there then upload pictures of pcb and phone Br Faisal_Computer |
I Love Pinfinder can't find any thing on this mobile.I will post all details in the future. |
yes, would be nice to know what MCU it is based On. then we can guess what to do next |
I love 5 Attachment(s) That mobile "I LOVE" have behind his cover mitionned RONIC R608. Connector for charger the same as Motorola V3...So the same charger,tested. I can see three chips on pcb(ARM-mtekvision-R22821JAPAN) Here is pictures::D |
I love ronic r608 3 Attachment(s) I don't finished detail,here is other pictures: |
hello! unfortunately, pictures are not clear enough to read exact CPU name. can you write here what is written on biggest IC? |
I love ronic r608 Here is what' written: ARM MT6223AA 0749-ANSL FAJKR6 I can't see well the end of this: FAJKR6 or FAJKRG Confusion is it G or 6,pcb not new one!:D |
hello! for this type of MCU pinout can easy be found using voltage measuring method: 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
I love ronic r608 All understand!But phone powered on or no? |
hello! not really important if it is powered or not. |
I love ronic r608 Ok! will try and post result.:D |
do you have the complete cables for chinese phones design to work with infinity box.then use one of the cables written on it TCL.it has port like that of mot v3.just connect it direct.tested and confirmed.good luck |
