09-28-2008, 09:20 | #2 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | its better to post pin connector type and upload some pictures and also open phone see witch CPU on it and try to find pins with pinfinder if you still fail to find then check RX tX on pcb is still not there then upload pictures of pcb and phone Br Faisal_Computer |
02-20-2009, 22:04 | #5 (permalink) |
No Life Poster Join Date: Sep 2005 Location: near Network Age: 48
Member: 185608 Status: Offline Thanks Meter: 592 | I love That mobile "I LOVE" have behind his cover mitionned RONIC R608. Connector for charger the same as Motorola V3...So the same charger,tested. I can see three chips on pcb(ARM-mtekvision-R22821JAPAN) Here is pictures: |
02-23-2009, 18:31 | #8 (permalink) |
Member: 185608 Status: Offline Thanks Meter: 592 | I love ronic r608 Here is what' written: ARM MT6223AA 0749-ANSL FAJKR6 I can't see well the end of this: FAJKR6 or FAJKRG Confusion is it G or 6,pcb not new one! |
02-23-2009, 20:15 | #9 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! for this type of MCU pinout can easy be found using voltage measuring method: 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
02-25-2009, 10:42 | #13 (permalink) |
Freak Poster Join Date: Jan 2006 Location: Nigeria
Member: 218859 Status: Offline Thanks Meter: 2 | do you have the complete cables for chinese phones design to work with infinity box.then use one of the cables written on it TCL.it has port like that of mot v3.just connect it direct.tested and confirmed.good luck |
How to find a pinout for Chinese phone? EASY! | Multi-box TEAM | Chinese Cocktail | 31 | 05-05-2012 20:54 |
Worked and tested pinouts for Chinese phones are here | GSMtricks | Chinese Cocktail | 32 | 10-22-2008 15:27 |
DOWNLOAD NOW " ONE LOVE " WAVE .... | TWISTER_FLasher | Nokia Multimedia | 7 | 03-17-2008 15:21 |
Need pinout for Chinese D500 and CECT 599 | Faisal_Computer | Infinity-Box | 7 | 12-14-2007 02:06 |
Pinout for chinese PDA D328 | KHJAMAL | Infinity-Box | 6 | 11-12-2007 09:19 |
