02-15-2010, 21:25 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software If it does supported, and you dont have infinity Pinfinder- i can teach how to find pinout in minutes. Just by measuring voltage on phone system connector pins. |
02-15-2010, 21:28 | #3 (permalink) |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | hi.. pls try this.. or check the pcb for pinout.. or check the under the imei sticker for pinout.. Code: software version: 1.20 cable type: 2x5 (L10C) platform: MT: MT6205, MT6217-MT6235 searching adapter at COM3... adapter found, version: 2000 pins: 10, plain power cycles: 1 activation cycles: 7 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Press and HOLD phone Power button now ! detecting pins... 19200 fixed CPU: MT6225 result: Rx:4 Tx:5 time required: 18 sec Trying to Power-On... Power On ! |
E71 and N96 died by normal FBUS flashing!! | Cake | HWK | 2 | 03-30-2010 08:10 |
plz pinout e71 tv b | angelhack | SpiderMan | 1 | 12-02-2009 23:24 |
Tested cable/pinout Nokia e71-1 help | xerx | Nokia Base Band 5 ( BB-5 ) | 0 | 01-12-2009 21:03 |
