02-26-2009, 22:38 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please post connector type. are you sure that this is mt62xx MCU based phone? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
02-28-2009, 23:19 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! last thing to try is following: attach battery power to phone terminals and next measure voltages on all available test points and system connector pins. as soon as you see 2,7-2,9 volts voltage- those pins are tx/rx |
02-28-2009, 23:26 | #7 (permalink) |
Freak Poster Join Date: Jun 2007 Location: EGYPT
Member: 521296 Status: Offline Sonork: 100.1574136 Thanks Meter: 21 | Thank You I Found PinOut Thank You I Found PinOut This Is Flash File .. http://www.4shared.com/file/90046629...000146B0M.html I Will Updat Flash File To Your e-mail |
The Following 2 Users Say Thank You to 3lsheikh For This Useful Post: |
05-23-2009, 11:52 | #9 (permalink) | |
No Life Poster Join Date: May 2001 Location: gujarat india
Member: 4600 Status: Offline Thanks Meter: 79 | Quote:
Please explain tx, rx . thx. | |
07-08-2009, 20:30 | #13 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! connect blue and red wire to pins 2,3 of RJ45 black, GND pin, connect to pin 8 of RJ45 if you cant get connection- swap Tx/Rx wires with places |
07-08-2009, 22:02 | #14 (permalink) |
Freak Poster Join Date: Nov 2006 Location: in the Royal Palm Land.... Age: 49
Member: 383033 Status: Offline Sonork: 100.1580642 Thanks Meter: 441 | Finally jmax j95 pinout Finally here is an image with the correct pinout for JMax J95 (Working 100%) more easy to understand. Infinity Support, you can use this image without problems to update pinout data base. Also received a message from Chinese Miracle Soft, something about a New Firmware Version detected. I copy the firmware and eeprom, maybe in a few days I upload both and send you the link for dowload. Thanks to elsheikh, I used his photo like a guide. With best regards................aslam870 |
The Following 3 Users Say Thank You to aslam870 For This Useful Post: |
07-12-2009, 18:49 | #15 (permalink) |
Member: 383033 Status: Offline Sonork: 100.1580642 Thanks Meter: 441 | Infinity Team here you are the Magaupload Link with Flash and Eeprom of new version of J Max J95 http://www.megaupload.com/?d=PO92YTQJ With best regards..............aslam870 |
Pinouts for Wi-Fi Mobile C5000 | Stoyan | Infinity-Box | 3 | 04-01-2010 06:06 |
unlock code for motorola i 95 cl nextel | ALIN | Phone Unlocking Codes & Maps | 0 | 11-01-2003 13:26 |
PinOut for GD 96 and 95 | Format1 | Panasonic | 2 | 05-23-2003 06:51 |
I have winmodo 1.3 for gd35 and 95 | AlexMobile | Panasonic | 5 | 08-29-2001 09:24 |
I have winmodo 1.3 for gd35 and 95 | AlexMobile | Exchange Section | 3 | 08-29-2001 08:55 |
