Old 01-23-2010, 16:44   #1 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 199
pinout J132 with pinfinder ?
hello all,
I have pinfinder, and would use the cable L5A for connecting to phone, anny one can give me pinout for Pinfinder or maybe edit pinout_db_user file and share it pls,
Because it's the second phone when I want use the pinfinder only like a cable, but not possible, maybe I'am wong some where ?
Best Regards,
JAVA Good.
Old 01-23-2010, 16:45   #2 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 199
hoooo, and I forget, how about chosse GND pls on pinfinder ?
Best Regards,
JAVA Good.
Old 01-23-2010, 18:06   #3 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
You can select pinout from existing PinFinder database: Sony-Ericsson-J120i
GND: it should be connected via PinFinder Power cable.
Old 01-23-2010, 18:10   #4 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 199
hooooooo, so GND it's from battery, so I can use it only if I use this RJ45 cable ? and if the reply is yes, it's possible to add option for chose the GND pin like Rx and Tx
Best Regards,
JAVA Good.
Old 01-23-2010, 18:42   #5 (permalink)
Member: 130995
Best Regards,
JAVA Good.
it's not possible to add GDN pin selection.
Please, download PinFinder manual: http://www.infinity-box.com/download..._PinFinder.pdf to avoid more questions in future
Old 01-24-2010, 19:10   #6 (permalink)
JAVA Good's Avatar
Member: 66136
Thanks Meter: 199
tks for you reply, so it's not possible to add a small adapter for use only GND, because pinfinder it's a verry nice product, but if I can't use it like an anny cable all the the time with RJ45 power cable, this is no verry good , anny idea pls ?
I power my brain tomorow for maybe find a smal solution for GND,
Best Regards,
JAVA Good.
help to unlock SE j132 with InfinityBo+Pinfinder noure30 Infinity-Box 18 01-22-2009 00:20
lg kg300 restarting solved with format also pinfinding with pinfinder joni_rajpura Infinity-Box 3 12-09-2008 14:01
nokia n73 with pinfinder pinout hans salim Infinity-Box 3 08-18-2008 21:22
Can't find pinout with PinFinder for Anycool C9000 loshh Infinity-Box 7 08-15-2008 12:13
How to find pinout with pinfinder ?? kabirhossain Infinity-Box 2 05-04-2008 22:07
Page generated in 0.28729 seconds with 8 queries
