01-28-2009, 14:25 | #1 (permalink) |
Freak Poster Join Date: Nov 2005 Location: united states Age: 43
Member: 201862 Status: Offline Sonork: 100.1603269 Thanks Meter: 23 | pinout k2000 chinese the usb cable only conect "mass storage" and "web cam" but not connected in port com, I need the configuration pinout for rj-45 to change the IMEI, thanks. this phone http://www.gsmatq.com/product_show.asp?id=499# |
01-28-2009, 15:34 | #2 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! please post connector type. are you sure that this is mt62xx MCU based phone? tip: you can check this by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
01-28-2009, 19:17 | #5 (permalink) |
Member: 201862 Status: Offline Sonork: 100.1603269 Thanks Meter: 23 | picture conector i have usb cable but not working in mode com onli usb storage , camera web. this is picture conector http://rapidshare.com/files/19075375...ector.rar.html thanks alot |
01-28-2009, 22:01 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! connector type L12C if you dont have pinfinder i can advice how you can find pinout using multimeter. you must do voltage measuring on all phone pins with attached battery. tx/rx pins will show voltage 2,7-2,9 volts Last edited by InfinityHelp; 01-28-2009 at 22:24. |
01-29-2009, 00:15 | #7 (permalink) |
Member: 201862 Status: Offline Sonork: 100.1603269 Thanks Meter: 23 | last question I have already found RX and RX are located on pins 2 and 8 I would now like to know what is rx and tx on port of the box as well as the location of the Gnd and the pin of telephone and pin of box? thanks |
01-29-2009, 11:22 | #8 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, 1. run Infinity-Box Shell 2. go to "Documentation" software page 3. you will see very important information with answers to all your questions Please, confirm, is that information was enough for you to build cable. |
01-29-2009, 16:50 | #9 (permalink) |
Member: 201862 Status: Offline Sonork: 100.1603269 Thanks Meter: 23 | good goooooooooood pinout connector type L12C for k2000 chinese pin 1..........12 keyboard up 5... Gnd 8... Rx 9... tx working 100% |
How to find a pinout for Chinese phone? EASY! | Multi-box TEAM | Chinese Cocktail | 31 | 05-05-2012 20:54 |
Worked and tested pinouts for Chinese phones are here | GSMtricks | Chinese Cocktail | 32 | 10-22-2008 15:27 |
Need pinout for Chinese D500 and CECT 599 | Faisal_Computer | Infinity-Box | 7 | 12-14-2007 02:06 |
Pinout for chinese PDA D328 | KHJAMAL | Infinity-Box | 6 | 11-12-2007 09:19 |
Help, I Need Cable Pinout N95 Chinese | AlexRom51 | Infinity-Box | 13 | 09-10-2007 09:50 |
