05-07-2008, 12:03 | #1 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 263548 Status: Offline Thanks Meter: 24 | Pinout for KE970 Im trying to unlock LG KE970 via Infinity box with Pin Finder adapter. But i don't which CPU that should I select under the Pin Finder(Automatic).Can someone pls help?thks! |
05-08-2008, 14:33 | #3 (permalink) |
Member: 263548 Status: Offline Thanks Meter: 24 | [IMG]file:///C:/DOCUME%7E1/Nicholas/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/Nicholas/LOCALS%7E1/Temp/moz-screenshot-3.jpg[/IMG]Hi, Do u mean select from Pin Selector (Manual)? then press Set button?? right? |
05-08-2008, 15:15 | #5 (permalink) | |
Yes, exactly. Please, see here manual how to make it, it's example for Sagem phone, but it will helps in your situation too: http://www./showthread.php?t=526956 | |
05-08-2008, 20:38 | #6 (permalink) |
Member: 263548 Status: Offline Thanks Meter: 24 | Hi, I have follwed the steps but the phone still cant detect by Infinity Box.The mesg is " Phone must be SWITCHED ON ! Connecting, wait... Connection Fail Finished " The phone can switch on...but when i press Read info button then happen that mesg again.. |
05-09-2008, 04:57 | #7 (permalink) |
Member: 263548 Status: Offline Thanks Meter: 24 | These r the steps that I did: From Auto Pin Finder box: 1)Press Detect Adapter 2)Select 1x18(L18B) 3)Select from Pin Selector(Manual) Rx 12; Tx13. 4)Press Power button. 5)Then i press on button from phone and now the phone is switch on. 6)Press Set button. Iget tis mesg "done Initializing... done Cable: 1x18 (L18B) Power On ! " 7)Then I open Infinity n the phone is still switching on. 8)Select Service tab. 9)Press Read info button. Then i got tis mesg: "Phone must be SWITCHED ON ! Connecting, wait... Connection Fail Finished " Any idea??Am I doing correct steps? Pls help!! thks!! |
05-09-2008, 14:14 | #10 (permalink) |
Freak Poster Join Date: Dec 2000 Location: Burkina Faso , Bobo Dioulasso Age: 53
Member: 2920 Status: Offline Thanks Meter: 21 | KE970 unlock , you can use KG800 cable or build one easly according to Pinouts given here and in Infinty Soft. I unlocked one KE970 , 2 days ago. Good luck. |
05-09-2008, 19:43 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, I found the problem: it's need to reverse pin numbers (keyboard top <-> keyboard down). You need to make this: 1. set Rx = 6 2. set Tx = 7 Now everything should be Ok. Waiting for your results. |
05-10-2008, 08:18 | #15 (permalink) | |
Be sure that you have connected + and - well and be sure that connector inserted well into phone. It can't be any mistake due to I have tested it yesterday with my own phone, it was the reason why I have suggested you to reverse pins. | |
Pinouts for Wi-Fi Mobile C5000 | Stoyan | Infinity-Box | 3 | 04-01-2010 06:06 |
how to enter unlock code for ke970 | izamer | LG | 10 | 05-19-2009 14:34 |
Any free solution for ke970 and u450? | Don2006 | LG | 5 | 07-14-2008 19:37 |
from wher download flash file for ke970 in vygis sopport? | CHAPRAN | VygisToolbox | 0 | 08-31-2007 12:01 |
need master code for ke970 | shervin | LG | 2 | 07-11-2007 14:52 |
