12-12-2008, 10:06 | #3 (permalink) |
No Life Poster Join Date: Sep 2004 Location: HR Age: 48
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | Similar to Samsung D800 Looks like this: Description: http://www.wt-gsmphone.com/sdp/53132...tml#normal_img |
12-12-2008, 21:44 | #5 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! lets start from checking what CPU it is based. you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button. if you will see "language set: english"- you can be sure, that this phone is supported by Infintiy software |
12-13-2008, 09:07 | #7 (permalink) |
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | I have USB drivers for it and when I connect it to PC I can choose COM Port option. It says USB device MT6227, then installs USB Modem. It connects to PhoneSuite i have... Can I connect it to Infinity like that? |
12-13-2008, 09:41 | #8 (permalink) |
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | Ok, I have connected it to Infinity using original USB cable and got this info: Hardware version: MT6225, E03 Hardware version: EVEN25_HW Software version: E307_JQ1F10.00.0_25S Software date: 2006.06.14 Barcode: E30709020039549 imei: 3575560007xxxxx But I can't flash it like that... |
12-15-2008, 19:59 | #11 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
12-16-2008, 16:48 | #13 (permalink) |
Member: 80391 Status: Offline Sonork: 100.1601620 Thanks Meter: 66 | Ok, so I get this: Keyboard is up, from left to right (1.......20) Pin no / Voltage (V) 10 / 2.79 11 / 2.73 13 / 2.76 14 / 2.82 16 / 2.73 Confused now..... |
12-16-2008, 20:16 | #14 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! i would try pins 13,14 try them in both way 13 as Tx, 14 as Rx and if will not work- otherwise 13 as Rx, 14 as Tx |
Pinouts for Wi-Fi Mobile C5000 | Stoyan | Infinity-Box | 3 | 04-01-2010 06:06 |
Connectivity for Metom m10 | deffa | Chinese Models & Cloned Phones | 2 | 05-21-2009 08:59 |
What is pinout for metom mt309? | ferhattas | Chinese Models & Cloned Phones | 0 | 09-08-2008 17:10 |
Pinout for N95 RM-17 like origin pinout needed | ..::alexis::.. | Infinity-Box | 7 | 05-09-2008 17:54 |
CAN SMB SHARE WITH ME PINOUT FOR MOTOROLAS (all what u have) plss, need for emmi | igor_m | Wanted Products | 0 | 09-21-2000 21:29 |
