Old 03-31-2009, 09:10   #1 (permalink)
bsat's Avatar
Member: 195225
Thanks Meter: 94
pinout n81 double sim
i need pinout n81 double sim.
calubration problem.
Old 03-31-2009, 14:41   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
hello,
What is this phone connector type ?
Old 04-02-2009, 12:13   #3 (permalink)
bsat's Avatar
Member: 195225
Thanks Meter: 94
Originally Posted by InfinitySupport View Post
hello,
20 pin thx my friend
Old 04-02-2009, 23:54   #4 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
i can teach how to find pinout using multimeter, but first need to check if this phone is mt62xx CPU based
you either can do this by disassembling phone or by typing *#0044# and pressing green (send) button.
if you will see "language set: english"- you can be sure, that this phone is mt62xx
Old 04-03-2009, 15:57   #5 (permalink)
bsat's Avatar
Member: 195225
Thanks Meter: 94
giv me pinout pls ...
Old 04-03-2009, 15:58   #6 (permalink)
bsat's Avatar
Member: 195225
Thanks Meter: 94
give me pinout pls my friendd
Old 04-05-2009, 11:24   #7 (permalink)
Member: 148515
hello!
1. set multimeter to voltage measuring.
2. check bettery voltage, it should be more than 3,7volts
3. set one multimeter probe to some grounded phone part
(if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal)
4. with second probe touch one by one all phone pins (phone battery attached, phone can be powered On or not)
(to get better result i would advice to set needle on the end of second probe)
memorise pins with voltage between 2,7-2,9volts.
those are tx/rx
i need pinout n81 dual sim. bsat Infinity-Box 5 02-05-2010 20:01
wants pinouts for cect u8800 double sim .. sandeepmansa Infinity-Box 2 12-28-2007 06:57
need pinout 6698 TV Mobile double sim farhanali Infinity-Box 4 12-19-2007 18:34
n92 double sim pinoute 22gsm Chinese Cocktail 4 12-19-2007 10:29
need pinout CM N95 double sim lidar Infinity-Box 2 12-15-2007 16:16
Page generated in 0.17981 seconds with 9 queries
