07-10-2008, 10:05 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Mediteranean
Member: 59352 Status: Offline Thanks Meter: 50 | pinout for n95 8GB rm-159 new the new N95 8GB rm-159 (same as original) différent with that in pinout image of infinity. connector same as v3 motorola. i tried with pinfinder (L14B) but no connection... thanks |
07-10-2008, 11:31 | #3 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Egypt Age: 46
Member: 99784 Status: Offline Thanks Meter: 865 | if you can see the GND, RX, TX under the simcard so the connector will not help you have to use the free cable wires and sold them to the GND,RX,TX after you open the phone |
The Following User Says Thank You to GalaxyMan For This Useful Post: |
07-26-2008, 13:23 | #5 (permalink) | |
Freak Poster Join Date: May 2007 Location: BetaMax Tester
Member: 516470 Status: Offline Thanks Meter: 70 | Quote:
if it is 10 pin USB Try this: [N95 8GB Chinese phone pinouts] USB pin 1 = GND pin 5 = RX pin 6 = Tx | |
07-26-2008, 17:56 | #6 (permalink) |
Freak Poster Join Date: Feb 2006
Member: 233949 Status: Offline Thanks Meter: 25 | i agree with galaxyman bro.... this is my log: COM3 [VCP3] selected Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: reset Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6226:8A02:8A01]... CPU: MT6226 high speed boot disabled chip: 0031541:FBC4 high speed disabled boot step size: 0002 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: ACEA80F098E59F:ACEA8000000000 flash: EC257E25082501:2CEA0000000000 flash: Samsung D 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb number of flash chip/regions detected: 02/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... device parameters autodetection in progress.. detecting chip #00 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb detecting chip #01 in region #00... flash: EC257E25082501:2CEA0000000000 flash: Samsung AMD/Fujitsu std [D 0008x002000 00FEx010000 0008x002000] 16Mb it's time to stop: 2C0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [enhanced] generation security area#1 is Ok security area#1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.8DF48BE6.[N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN_E18EF9B1].rpl identification#1 detection finished device-id: 8DF48BE6 identification#1 protocol ver: 04 ver. sw1: N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN ver. sw2: MAUI.06B.W07.04.MP.V32, 4E06711E ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished detecting eeprom/ffs area in 1 chip(s)... standard eeprom/ffs offset detected: 00E00000 flash: EC257E25082501:2CEA0000000000 checking area[00000000]: 00000000-00FFFFFF... eeprom/ffs found near: 00E00000 detecting eeprom/ffs size... eeprom/ffs size: 00200000 ffs chip: 00 eeprom/ffs area: 00000000:00E00000-00FFFFFF Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN]]... file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_eeprom[N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_04_MP_V32.B IN]_20080725-122501.B0E.bin flash: EC257E25082501:2CEA0000000000 Backup required data Done Patch required data... Patch required data Done Special operation... Special operation Done Write... Write Done Finalization... formatting... flash: EC257E25082501:2CEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_system_log _8DF48BE6_N95_PCB01_GPRS_MT6226_S01.MAUI_06B_W07_0 4_MP_V32.BIN_E18EF9B1_20080725-122523.B0X.bin Finished, time used: 202 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
Pinout N95 8GB RM-159 | Atlas_marc | Infinity-Box | 4 | 01-15-2010 15:54 |
N95 8gb Rm-159 New Model Pinout Finded 100% Working | K.SIVAJI | Chinese Models & Cloned Phones | 0 | 12-13-2009 10:33 |
N95 8Gb Rm-159 pcb pinout | TEHGSM | Infinity-Box | 2 | 08-12-2009 07:26 |
please help with pinOUT FOR N95 8GB RM 145 | ServiceTEL | Infinity-Box | 12 | 06-06-2009 04:47 |
Need firmware N95 8GB RM-159 | Arraniri | Infinity-Box | 5 | 08-20-2008 11:34 |
