10-10-2011, 09:45 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: in your Heart
Member: 1484062 Status: Offline Sonork: 1610135 Thanks Meter: 218 | Alcatel 355x After Unlock dead? which matter unlock after dead. read file this set . . .. Alcatel-355X,355A__system_log_E5765BC2_5DE28CEF_20111010-122232.B0X.bin - 4shared.com - online file sharing and storage - download plz solved this matter plz . . . . . thanx in abvance . . . . |
10-11-2011, 11:03 | #6 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1670509 Status: Offline Thanks Meter: 0 | we have same prob. bro., but i fixed them hirs. my logs COM17 [VCP0] selected module v4.01 Device: Alcatel-355X, 355A Checking data, wait... advanced flash detection enabled Action: write flash "smart write" active write: Firmware 355X-2APMPT1-46A_XI46CM60_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI _08A_W08_36_SP1_V34_2010-11-01_En_Fr_Es_De_Pt.B0M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 high speed boot On chip: 0011:8CA6:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:FFFFFF00000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 230400 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00C00000/00400000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35392304225781 Backup required data Done ====> Patch required data ... Patch required data Done ====> Special operation ... Special operation Done ====> Write ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... . search rom info finished searching rom info... . search rom info finished warning: rom info information not found, possible reasons: - old firmware type w/o rom info information - empty (completely or partially erased) flash chip - damaged firmware - damaged hardware (bad soldered or damaged flash chip) > if phone works fine just ignore this warning < ffs/eeprom address can not be detected, value from database assigned: 00C00000/00400000 sec info (fast) detection... searching sec info#1... . search sec info#1 finished usb bootloader (file) is absent startup code area #1 check... startup code area #1 calculation... startup code area #1 fixed file saved: c:\InfinityBox\MModule\backup_security\Alcatel-355X,355A__system_log_20111011-081127.B0X.bin Area: Firmware flash: 01227E22202200:FFFFFF00000000 Write: Firmware usb bootloader (file) is absent sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CI46CM60 customization name adjusted customization: CI46CM60 customization name adjusted customization detected: CI46CM60 customization: CI46CM60 flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, cust) security area (sec info, cust) calculation done security area (sec info, hash) calculation... ..................security area (sec info, hash) detecting size... security area (sec info, hash) detecting parameters... security area (sec info, hash) encoding... done flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: security area (sec info, hash) security area (sec info, hash) calculation done Write Done ====> Finalization ... Finalization Done file saved: c:\InfinityBox\MModule\backup_security\Alcatel-355X,355A__system_log_20111011-082833.B0X.bin Finished, time used: 17 min 33 sec Remove/Install battery now ! |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
FAQ about unlock n0kia | man0n | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-29-2010 19:06 |
