05-05-2009, 16:49 | #6 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! 1. set multimeter to voltage measuring. 2. check bettery voltage, it should be more than 3,7volts 3. set one multimeter probe to some grounded phone part (if you cant find grounded part outside phone- you need to take out small thin wire from negative battery terminal) 4. with second probe touch one by one all phone pins (phone battery attached, phone can be powered On or not- doesnt metter) (to get better result i would advice to set needle on the end of second probe) memorise pins with voltage between 2,7-2,9volts. those are tx/rx |
The Following 2 Users Say Thank You to InfinityHelp For This Useful Post: |
tx/rx taxco tx61 | cscdalung | SpiderMan | 2 | 10-20-2009 05:26 |
Pinout Taxco DM79 | YAVIE | Infinity-Box | 3 | 07-21-2009 20:55 |
Taxco TX60 Need Help | dany_kroya81 | Infinity-Box | 10 | 02-27-2009 15:55 |
pinout Taxco TX60 | r31h4n | Infinity-Box | 4 | 11-23-2008 21:08 |
