12-04-2007, 15:26 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: Tunisia Age: 46
Member: 145648 Status: Offline Sonork: 100.100487 The_Gorr Thanks Meter: 23,034 | Pinout Tn710 correction ... infinity gived this pinout http:///vbb/showpo...12&postcount=2 and also there is this pinout on support area : keyboard top 1.........18 1: Gnd 2: Gnd 13: phone Rx 14: phone Tx the problem is must be written keyboard down not Top so correct pinout must be: keyboard top 1.........18 17: Gnd 18: Gnd 5: phone Tx 6: phone Rx test: COM1 [Serial0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Set baud... 115200 Set baud Ok Read info... flash: 89885500010001:89885500000000 flash: Intel 28F640W30-B B 8Mb Read info Ok Check flash... Check flash Ok Check space... reading... file saved: backup_eeprom_calibration__20071204-151647.70E.bin error: wrong eeprom address range Check space failed Finished, remove/install battery now ! Time used: 14 sec so test and post result br <= The_Gorr => |
10-19-2008, 15:04 | #3 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Here
Member: 39196 Status: Offline Thanks Meter: 126 | yes i confirmed : COM3 [VCP0] selected Checking data, wait... Phone should be Switched OFF ! Connect... Press Power button now ! Connect Ok Boot... Boot Ok Read info... Flash ID: 0089:0055 Read info Ok Set baud... 115200 Set baud Ok Check flash... Check flash Ok Check space... reading... file saved: backup_eeprom_20081019-160259.70X.bin Check space Ok Write... Write: EEPROM Write Ok Close... Close Ok Restart... Restart Ok Finished Remove/Install battery now ! Time used: 36 sec |
N328 pinouts 1000% correct | ikkks | Infinity-Box | 5 | 05-16-2008 21:37 |
TN710 Correct pinouts ? | abdoune | Infinity-Box | 8 | 08-15-2007 16:05 |
X 60 which pinout is correct | naje | Redbox | 2 | 10-11-2006 11:25 |
Siemens C30 pinouts - correct or not? | GSMdEvil | NON Siemens Brand (ODM Phones) | 0 | 03-18-2001 12:36 |
pinout 939 NOT correct ? | Squesch | Infineon C16X M51 & ARM7 M52 BASED | 2 | 05-16-2000 12:29 |
