04-27-2012, 11:26 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Western Cape, South Africa
Member: 10168 Status: Offline Thanks Meter: 153 | Anyone used Infinity with Donod D805? I have tried JTAG directly on the board (these are clearly marked) and also using Pin Finder but nothing will connect!! As I say, I have several units that require the user code reset and even brand new units but none will connect! Donod D805 is shown as supported but has anyone actually done one of these devices or is it only theoretically supported?? |
The Following User Says Thank You to jim.mahoney For This Useful Post: |
04-27-2012, 11:59 | #3 (permalink) |
Member: 10168 Status: Offline Thanks Meter: 153 | I have just tried this with no luck! I am reasonably certain it is MTK 6225 because if you connect a normal working handset via USB it detects it as a 6225 and loads MTK drivers! If I could get this phone to enable it's USB port, then I'm sure I could reset the user code in that way... Sadly, if the user code is set then plugging in a USB cable has no effect much like a BB5 Nokia! |
04-28-2012, 12:10 | #4 (permalink) | |
No Life Poster Join Date: Apr 2007 Location: M W Balasore,Odisha,INDIA Age: 52
Member: 492222 Status: Offline Sonork: 100.1594126 Thanks Meter: 10,377 | Quote:
This is strange ........ Can you please upload the PCB picture ? Br - srinibas | |
04-30-2012, 22:30 | #7 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | hello! use test points on PCB and RJ45 port of our box. Tx goes to pin 3 of RJ45 Rx goes to pin 2 of RJ45 grounded PCB part must be connected with pin8 of RJ45 Phone's battery charged fully and attached good luck |
05-03-2012, 11:46 | #8 (permalink) |
Member: 10168 Status: Offline Thanks Meter: 153 | Thanks for the information. Sadly, I have been checking and the Tx/Rx points on the PCB are not connected to anything (i.e. the UART) although marked as Tx/RX/Gnd on the PCB!! Although they are Donod D805 the handsets are branded Mobitel (a local South African company) and this makes me convinced that they have had the serial ports disabled. There are also no Tx/Rx points available on the USB port either. Only D+ and D- USB signals which are not enabled if a user password is set at startup (much like a Nokia BB5) if I could get the USB enabled, I could probably read the code... |
05-17-2012, 11:15 | #9 (permalink) |
Member: 10168 Status: Offline Thanks Meter: 153 | Just to update this thread a little... It seems that there are both MTK 6225 and Spreadtrum 6600 versions of this handset! Green Board = MTK 6225 Based Blue or Red/White Board = Spreadtrum 6600 Based I hope to have manufacturer supplied service cables soon. Once I have these and work out how they enable the USB port on this handset, I will post the information here. |
05-17-2012, 17:27 | #10 (permalink) |
No Life Poster Join Date: Aug 2008 Location: Côte d'Ivoire_Ghana_Nigeria Age: 40
Member: 846968 Status: Offline Sonork: 100.1613167 Thanks Meter: 139 | hi bro i can see you are old user but can you put log here we can see what happen too i think i have done this model before no problem on fone top before????? wbr zemica |
06-12-2012, 21:26 | #12 (permalink) |
Member: 10168 Status: Offline Thanks Meter: 153 | Here's the answer: This handset is Spreadtrum 6600L based. The only way to reset the code is to flash with original Spreadtrum flasher using Infinity Box (for COM Port) and J-TAG soldered onto Tx/Rx & Gnd on board. No Infinity software should be running. The Tx/Rx connections are NOT connected to the USB socket on this version of the handset. I hope this helps someone else... |
NHE_8 wont work with NHEK5689.dll v3 | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-23-1999 15:48 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Netmonitor with FBus???? | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 06-09-1999 17:04 |
