01-06-2011, 09:47 | #1 (permalink) |
No Life Poster Join Date: May 2007
Member: 503911 Status: Offline Thanks Meter: 195 | LG KP320 Flashing error COM4 [VCP0] selected module v3.71 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610TR00-001-R1A_En_Fr_Es_Pt_It_De_Tr.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610TR00-001-R1A.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... detect sec ro... detect custom parameters... detect project-id... detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: header is empty: probably flash chip completely erased warning: can not detect header nfi area detection (0 cores) finished: failed warning: ffs can not be detected TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610TR00-001-R1A.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . write core... error: can not write flash: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST error: last error: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST Disconnect... done Finished, time used: 1 min 25 sec Remove/Install battery now ! |
02-20-2011, 17:02 | #3 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Algeria
Member: 237474 Status: Offline Thanks Meter: 53 | not solved hello i have the same error with 2 LG KP320 i do full formate Whol flash ship but still error battery full i worck with MModulev3.71 PHP Code: thanks |
02-20-2011, 18:43 | #4 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: John Kemeny1926-1992 Age: 57
Member: 136220 Status: Offline Thanks Meter: 408 | Quote:
02-22-2011, 08:58 | #7 (permalink) | ||
Member: 237474 Status: Offline Thanks Meter: 53 | Quote:
but same result with china meracle Quote:
I receive the 2 phone dead is ther any auther solution | ||
02-24-2011, 20:15 | #8 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | If phone can not power-on well after you have tried to flash it with different firmware files - there is a big chance that it's a phone hardware damage but not a software fault. |
03-06-2011, 22:13 | #9 (permalink) |
Freak Poster Join Date: Jun 2010
Member: 1331936 Status: Offline Thanks Meter: 12 | have same problem with kp320 tested with good hardware phone ! but always dead it format OK format WHOLE FLASH OK but don't write anything same error below ! i think it's software bug not hardware take a look there : http://forum.gsmhosting.com/vbb/f296...kp320-1125782/ http://forum.gsmhosting.com/vbb/f296...oblem-1081043/ http://forum.gsmhosting.com/vbb/f296...roblem-971003/ |
03-06-2011, 23:44 | #10 (permalink) | |
It was working well during several months, then one day keys become non working etc. etc. it was hw fault, PCD fault or bad soldered CPU and/or flash chip, so, please, better read my own story well instead of talk about software problems. Also, you did not post any word about your phone problem, you did not post operation logs, so what we talk about now ? | |
03-08-2011, 00:59 | #11 (permalink) | |
Member: 1331936 Status: Offline Thanks Meter: 12 | Quote:
for sure i didn't post anything here because i receive many times a good hardware dead LG KP320 ! you have a pb with one kp320 that it was hw faulty but if open your eyes and read log below and the three threads you see always that : Code: TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done code offset: 00000000 ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610TR00-001-R1A.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... write bootloader... . . . . . . write core... error: can not write flash: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST error: last error: 0BEA:S_DA_NFB_BOOTLOADER_NOT_EXIST Disconnect... done Finished, time used: 1 min 25 sec Remove/Install battery now ! so perhpas i'm wrong and there is big hardware problem and perhpas not so what do you want to see in my log another than what you see below ? | |
03-08-2011, 10:12 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | As I can see you did not posted real operation log from operations that was done with your phones, you just re-post part of operation log text from other message from current thread. Yes, I understand that you are high qualified person (but why you simply can not post operation log ?) and you know about phones so much (but why you can not explain what is the problem with your own phone ?), but, please, be more smart this time and do not post problem description like "same prublum", but if you are really high qualified person act like a high qualified person and post detailed explanation for each your phone problem with your own operation log. |
03-08-2011, 10:46 | #13 (permalink) | |
you have always SAME PRUBLUM when some one say it's software bug i don't say i'm highcalified person but if you say that then thank u for appreciation i think you should treat your customer with more respect ! i don't have log here and i will not post since you have talk like this my hope was to help not to spam and good luck No more comment | |
03-08-2011, 11:09 | #14 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Sure, no more comments. It's ordinary answer when I ask somebody to explain problem well instead of post explanation like "same prublum". Please, make "search" in this forum and you will see that there are 2 (two) big problems for almost all phones: Problem #1 description: not work Problem #2 description: same problem We have no solutions for problem #1 and for problem #2, so if you want to get help - try to prepare description #3. Yes, I understand that it's morre hard that #11 and #2, but in 99.9% "description #3" gives perfect results. So, please, be honest and do not write any more something like "you should treat your customer with more respect" due to we respect our users really well, and you can see it if you will check this forum little bit more detailed. Also, to make your life little bit more easier I'll post here several sample messages that I have in my notebook, probably you will understand why I have made that samples. ============================= Dear Friend, Could you, please, explain your problem/question in details so we will be able to give you detailed answer. Thank you ! ============================= Hello, Could you, please, make more detailed explanation of problem, attach operation logs etc. We need to see detailed information about problem, what steps you have tried to do and what was the results after each step and only in this case we will be able to make required changes in software. Thank you ! ============================= Dear Friend, Please, tell me, what was the problem with phone and what you have tried to do exactly. - What was with phone when you got it ? - Did you tried to flash it ? - If yes, what flash files you have used ? - Did you tried to unlock phone ? - What was the results ? - What was original phone firmware version ? - Do you have original full flash backup ? Also, please, post here operation logs for each operation. Thank you very much for your explanation ! ============================= Now, please, make "search" in current forum and post here number of my posts with similar text. I'll be waiting for your statistical data even before your explanation of KP320 problem. |
05-18-2011, 14:19 | #15 (permalink) |
Freak Poster Join Date: Aug 2006 Location: in ***'s hand
Member: 326924 Status: Offline Thanks Meter: 31 | i hv one same phone..i was alve before after i formated the phone became dead..this is log : COM5 [VCP1] selected module v3.80 Device: LG-KP320 Checking data, wait... Action: write flash NAND write: Firmware KP320-00-V10d-ESA-XX-JUN-24-2008_A7610_07A_PCB03_GPRS_MT6229_S02.7S7610AA00-001-R1D_En_Ml_Id_Th_Vn_Cn_Cn.B4M.bin skip: Customization/Language Pack skip: Customization skip: Eeprom/ffs nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610AA00-001-R1D.bin nfi area detection (3 cores) finished: Ok interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6229:8A02:8A02 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0014]: 0098:00F100900095 [TOSHIBA] TC58NVG0S3AFT chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00020000 external RAM: S_DA_RAM_ERROR done Set baudrate (921600)... done ram test... testing 32bit... 32bit ram test passed testing 16bit... 16bit ram test passed ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02000000/06000000 firmware size: 32Mb ffs size: 96Mb detect sec ro... detect custom parameters... detect project-id... project-id: 7S7610AA00-001-R1D detect NAND info... number of areas/bytes to read: 1:00080000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... warning: incorrect header: 024F0F540C4F01440552210016303035 warning: can not detect header nfi area detection (0 cores) finished: failed TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 04 sw version: A7610_07A_PCB03_GPRS_MT6229_S02.7S7610AA00-001-R1D.BIN project-id: 7S7610AA00-001-R1D, 00000000 code offset: 00000000 ffs offset/size [01]: 02000000/06000000 rom info structure: [standard] type (04) TCL-ID is absent ===> done nfi area detection... external bootloader is not present bootloader version: A7610_07A_BOOTLOADER_V005_MT6229_7S7610AA00-001-R1D.bin nfi area detection (3 cores) finished: Ok startup code area #1 check... done number of cores: 3 loading files... number of areas: 3 done write... error: can not write flash (0): 0BBF:S_DA_RAM_ERROR error: last error: 0BBF:S_DA_RAM_ERROR Disconnect... done Finished, time used: 35 sec Remove/Install battery now ! error when i try to flash with firmware from support area.. |
need to flash 6110 | paulomt1 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-16-2019 19:37 |
5110 flash new software , need help | steve | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-03-2015 05:41 |
where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-12-2012 13:26 |
error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-28-1999 15:57 |
