09-30-2007, 20:27 | #8 (permalink) | |
You can use Infinity-Box two "format" options: "complete" and "safe" and bothoptions should be used with the same pinout. Only "Imei" option can be used with other pinout (ordinary USB data/modem cable and USB drivers). | |
09-30-2007, 21:42 | #9 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Algeria
Member: 96141 Status: Offline Thanks Meter: 200 | so dificult to find the right pinout, i think format will solve my problem, the phone hang and restart with sim card where are the chinese? it's ur phone! |
10-01-2007, 12:22 | #11 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 44
Member: 53457 Status: Offline Thanks Meter: 9 | @a203 keypad up left 1 to .... 3 and 4 are tx and rx @a203 keypad up left 1 to .... 3 and 4 are tx and rx its 100% woring if not work swap rx and tx ok best of luck best regards cellworld |
10-01-2007, 17:28 | #13 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
10-02-2007, 07:22 | #15 (permalink) | |
No Life Poster Join Date: Jun 2004 Location: Azerbaijan Age: 38
Member: 68498 Status: Offline Thanks Meter: 152 | Quote:
Would be great if you could add this option to your software too | |
pinouts for sands a203 | sunnny | Infinity-Box | 9 | 11-11-2007 18:00 |
NEEDED Sands A203 pinouts | kasim | Infinity-Box | 1 | 09-27-2007 13:37 |
need pinout for sands A203 | ashok_kumar459 | Infinity-Box | 3 | 09-24-2007 06:06 |
sands a203 pinout????????? | edy2002gha | Infinity-Box | 3 | 09-12-2007 21:16 |
plz help me pinout for SANDS A203???? | black snake | Infinity-Box | 9 | 09-11-2007 10:01 |
