Old 10-02-2007, 09:35   #16 (permalink)
Member: 130995
Thanks Meter: 35,227
Originally Posted by systemworm View Post
I agree with you but this soft formats phone when the phone is powered on
Would be great if you could add this option to your software too
As you can see there are two ffs format methods released by Infinity-Box:
"complete": phone is in powered-off state
"safe": phone is in powered-on state
Old 10-02-2007, 19:44   #17 (permalink)
systemworm's Avatar
Member: 68498
Thanks Meter: 152
Ok thanks for info I didn't know it.I always used the traditional method and even haven't checked any other options
Only sometimes use advanced chip detection method and boot baudrate autoselect box
Old 10-03-2007, 00:10   #18 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
i found it!
it was right, same like posted, but the mistake is keypad down not up
gnd 3
tx 13
rx 9
i can read info
Action: read information
Model: Autodetect 6205-6227 NOR
Checking data, wait...
Phone should be Switched ON !
Connecting, wait...
Phone detected, wait...
Hardware version: MT6226, E02
Hardware version: TELSDA26_05C_HW
Software version: MAUI.05C.W06.16.MP.V
Software date: 2005.04.12
Barcode: MT012345678901234567
imei: 35xxxxxxxxxxxxxx
Finished, time used: 9 sec
Power off phone now !
but i can't format:
COM1 [VCP5] selected
19200
error: boot phase#2/1 failed
error: can't initialize test moide
Operation failed !
Finished, time used: 3 sec
Remove/Install battery now !
Old 10-03-2007, 14:13   #19 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
that is why always before assembling cable is good idea to check with multimeter if real GND pin is on same pin as on given pinout
Old 10-03-2007, 16:12   #20 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
i can onely read phone info, but i cant flash, format.
Old 10-03-2007, 18:58   #21 (permalink)
Member: 148515
hello!
for all other operations phone must be switched off.
please note that while you booting phone you must hold power button all the time presses until soft asks to release it.
this is important condition for booting phone
Old 10-03-2007, 21:37   #22 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
hello!
yes i did it while phone is off, and i hold power botton
pls tell me, if i can read phone is my cable ok?
Connecting, wait...
Old 10-04-2007, 00:46   #23 (permalink)
Member: 130995
Yes, your cable is Ok.
Use "complete" format method instead of "safe"
Old 10-07-2007, 18:09   #24 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
same error always, is this phone supported by infinity?
br
Old 10-07-2007, 19:20   #25 (permalink)
Member: 130995
br
This phone supported by Infintiy-Box !
You must read detaioled description here: http:///vbb/showthread.php?t=449733
Old 10-08-2007, 00:53   #26 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
thank u, it's supported, solved!
br
Old 10-08-2007, 15:27   #27 (permalink)
Member: 171281
Thanks Meter: 26
A203
br
how did you solve the problem with infinity? pls post confirmed pinouts plllllsssssssssss
Old 10-08-2007, 16:47   #28 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
the pinout is posted http://forum.gsmhosting.com/vbb/show...82&postcount=7 by n3gr0 same like zt-199.
Old 10-09-2007, 14:45   #29 (permalink)
Member: 66460
Sonork: 100.1591321
Thanks Meter: 16
hi to all
i have same problem in sands A203
when try to read general infomation every thing ok
Connecting, wait...
imei: 357617006522946
Finished, time used: 5 sec
But when try to read eeprom or full flash
ther the message
COM4 [VCP0] selected
Device: Autodetect 6205-6227 NOR
advanced flash detection active
Action: read eeprom
Boot...
baud autodetection active
19200
Connecting, wait...
error: boot phase#1 failed
Release Power button now !
in case of initial connection problem: on/off "Boot baudrate autoselect" box.
Boot Fail
Finished, time used: 4 sec
i try software infinity box V1.56
and the pin out
3: Gnd
9: Rx
13: Tx
and try pin out same ZT-199
but same problaem
if some one help
10x to all members
Old 10-09-2007, 15:15   #30 (permalink)
Member: 66460
Sonork: 100.1591321
Thanks Meter: 16
and when i try to unlock the user loch
19200
Can't initialize test mode !
Possible reasons:
1. communication fault, repeat required operation
2. eeprom serious damaged, use repair eeprom files or use other unlock/format method
Operation failed !
Finished, time used: 434 sec
i try to found the repair eeprom file but nothin in the support
i need eeprom for sands A203
and flash file with arabic lp
10x to all
pinouts for sands a203 sunnny Infinity-Box 9 11-11-2007 18:00
NEEDED Sands A203 pinouts kasim Infinity-Box 1 09-27-2007 13:37
need pinout for sands A203 ashok_kumar459 Infinity-Box 3 09-24-2007 06:06
sands a203 pinout????????? edy2002gha Infinity-Box 3 09-12-2007 21:16
plz help me pinout for SANDS A203???? black snake Infinity-Box 9 09-11-2007 10:01
Page generated in 0.28884 seconds with 9 queries
