10-04-2007, 00:42 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Due to a lot of different models with the same name but absolutely different hardware, bottom connectors and different pinouts we recommend you to make detailed description of model, attach phone photo, phone bottom connector photo and information about Gnd and Charge pins on phone bottom connector. After you have this information prepared, please, check the next detailed description how to get pinout for your model: use "Cable Selector": http://forum.gsmhosting.com/vbb/showthread.php?t=398297 if not helps, please read: C:\Program Files\InfinityBox\pinout\ChineseMiracle.txt if not helps, please read: http:///vbb/showpo...36&postcount=7 if not helps, please read: http:///vbb/showthread.php?t=433447 |
how find pinout of infenion e gold cpu using PAD | zonetrichur | PadFinder box | 1 | 08-08-2009 19:03 |
Dear GSMTricks My Pad FInder Cant FInd Pinouts Always Gives Diffrent Pinouts | lovingazmee | PadFinder box | 33 | 03-04-2009 09:28 |
pad finder box ok in search pinout but always error connect | bhoybits99 | PadFinder box | 5 | 12-24-2008 09:23 |
Pad Finder Always Failed To Detect Pinouts | lovingazmee | PadFinder box | 3 | 07-10-2008 00:20 |
Pad Finder Pinout tested here!! Also Combine to Multibox!! TESTED!! | bestncheap | PadFinder box | 1 | 04-07-2008 07:56 |
