Old 11-13-2014, 04:26   #1 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
Lvtel model-v6 not done see here
PHONE IMAGE
PROBLEM SHOW LVTEL LOGO
I TRY TO IDENTFY
SEE REPORT
Operation : Check / Read Info [ v1.06 ]
Wait for phone...
Phone found! [ 3 ]
Sync...
Inital regs read done
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BB_CPU_NM : [MediaTek] MT6572_S00
Processing BROM stage
BLVersion : 0x01
SecCfgVal : 0x00000000
BromVersion : 0xFF
BLVersion : 0x01
Preloader Status : Alive
Processing DA stage
DA Select done , sending
NAND_ID : 009800BC009000660076001600080000
eMMC_ID : 00000000000000000000000000000000
DA Stat : v4.2 on BBID : 0x88
DA Sent. Configure setting now ...
NAND FlashIC initialized
[NAND] : FLASH_VEN : 0x0011 , [KINGSTON] KTN0403CS_TCR1
[NAND] : FLASH_DIE : 0098 00BC 0090 0066 0076 0016 0008
[NAND] : FLASH_LEN : 0x20000000
INT RAM : 0x00020000
EXT RAM : 0x10000000
BOOT TYPE : NAND_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
Info read not done Erased phone or unsupported FlashIc?
Done!
Elapsed: 00:00:12
Reconnect Power/Cable!
FORMATE REPORT
Operation : Format FileSystem [ v1.06 ]
Wait for phone...
Phone found! [ 7 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0xFE
BromVersion : 0x05
BLVersion : 0xFE
Preloader Status : Not active (Erased)
Processing DA stage
Configure emi settings
SOC VERIFY : C1
Boot Ok!
Error read initial info , blank flash or wrong settings?
Operation Failed
Elapsed: 00:00:19
READ FULL FLASH READ REPORT
Phone found! [ 3 ]
Sync...
Boot Info :
BB_CPU_ID : 6572
BB_CPU_HW : CA01
BB_CPU_SW : 8C00
BB_CPU_SB : 0000
BLVersion : 0x01
BromVersion : 0xFF
BLVersion : 0x01
Processing DA stage
SOC VERIFY : C1
Boot Ok!
Reading Flash Conent now ...
NAND settings not exists, will check now ...
Settings read Ok!
- > Re-connect battery and start operation again!
Done!
Elapsed: 00:00:37
PLZ HELP HOW TO DO I TEST 2 PHONE
BOTH BAD REPORT
Old 11-13-2014, 04:43   #2 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
after maney step i read file now i try to write [who read file infinity]
show bad file detect
may be some bug ya i dont know how to do
here is image
Old 11-13-2014, 11:46   #3 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Zip and Upload that file somewhere to make that flash ic suported.
Page generated in 0.14116 seconds with 8 queries
