10-04-2017, 15:39 | #1 (permalink) |
Junior Member Join Date: Jun 2003 Location: Ukraine Age: 46
Member: 30978 Status: Offline Thanks Meter: 3 | Please add model Lenovo k10a40. I temporarily replaced the original Infinity Download Agent MTK_AllInOne_DA_SP loader for the Download Agent from the SP_Flash_Tool_v5.1616.00.000 DA_SWSEC_CRYPTO20_K10a40.bin And the phone was connected. P.S. Maybe in SP: Select Model.. Thaks. |
10-04-2017, 15:53 | #2 (permalink) |
Member: 30978 Status: Offline Thanks Meter: 3 | Logs for connect an Reset All but in the end of a reading the flash - received a warning: |
The Following User Says Thank You to SDGen For This Useful Post: |
10-04-2017, 22:14 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,770 | @SDGen That model uses factory signed flash files, there is no use of flash reading. Only factory, signed, stock rom's can be used for flashing. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following User Says Thank You to Brka For This Useful Post: |
10-02-2018, 11:09 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Lenovo Vibe C2 (K10a40) BOOT PROBLEM SOLOTION Lenovo Vibe C2 (K10a40) BOOT PROBLEM SOLOTION https://prnt.sc/l16mt0 HERE IS THE BOOT FILE...... https://mega.nz/#!0hsCASrY!Qf5N9m3orakaswRvN89TZsehs9TOrUR-3jtB9NfF8FE Code: ========================= Start ========================= 10/2/2018 / 12:40:25 PM ========================================================= Card found : S/N : D18A9025 , v0136 Chinese Miracle II [MTK module] v 1.58 ========================= Start ========================= 10/2/2018 / 12:41:22 PM ========================================================= Card found : S/N : D18A9025 , v0136 Chinese Miracle II [MTK module] v 1.58 ========================= Start ========================= 10/2/2018 / 1:03:21 PM ========================================================= Card found : S/N : D18A9025 , v0136 Chinese Miracle II [MTK module] v 1.58 Start at : [10/2/2018 / 1:03:53 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed ========================= Start ========================= 10/2/2018 / 1:34:32 PM ========================================================= Card found : S/N : D18A9025 , v0136 Chinese Miracle II [MTK module] v 1.58 Start at : [10/2/2018 / 1:34:46 PM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32323777850042EF29A5AC Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42008577ACA583EF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA9DCA437F544C981515EFB9C7A21BD00 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : Lenovo ProdName : K10a40 ProdModel : Lenovo K10a40 Device : K10a40 AndroidVer: 6.0 MTKxCPU : MT6735 MTKxPRJ : alps-mp-m0.mp1-V2.39.1_lcsh6735m.35u.m_P51 SECURITY : IMEI_SW [1] : 860198037902955 IMEI_SW [2] : 860198037932952 BTMAC Addr : 4888CAD835F4 WiFi MAC : 4888CADC35F4 MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V79_P19_1_lwg_n EXTRA : LCD : Not info available :( LCD Res : 1280x720 TOUCH [0] : GT1XX CAM [0] : imx219_mipi_raw CAM [1] : imx219_mipi_raw_ofilm CAM [2] : ov5695_mipi_raw CAM [3] : ov5695_mipi_raw_ofilm MODEM : lcsh6735_65t_ln_m_lwg_dsds LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:11 Reconnect Power/Cable! Finish at : [10/2/2018 / 1:34:57 PM] Start at : [10/2/2018 / 1:35:11 PM] Operation : Read Pattern/DP Lock [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32323777850042EF29A5AC Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42008577ACA583EF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA9DCA437F544C981515EFB9C7A21BD00 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading data ... [Info] : PatternLock Not Set! [Info] : DP Lock not set! Done! Elapsed: 00:00:10 Reconnect Power/Cable! Finish at : [10/2/2018 / 1:35:21 PM] Start at : [10/2/2018 / 1:35:32 PM] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 22 ] Sync... Inital Boot Ok! BB_CPU_PID : 6737 BB_CPU_NME : [MediaTek] MT6737M|MT6737_S00 BB_CPU_EXT : 0xCB00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 460001154D32323777850042EF29A5AC Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BM227 [eMMC] : FLASH_CID : 150100463732324D42008577ACA583EF [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00080000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xA9DCA437F544C981515EFB9C7A21BD00 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Clear DIN Clear Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:26 Reconnect Power/Cable! Finish at : [10/2/2018 / 1:35:59 PM] |
The Following 2 Users Say Thank You to ..::AppleLinks::.. For This Useful Post: |
