10-20-2016, 14:04 | #1 (permalink) |
No Life Poster Join Date: Jan 2009 Location: India
Member: 949240 Status: Offline Thanks Meter: 86 | please add this qcom ic Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 02C5919D ID_BLOCK_I : 009900E1 ID_BLOCK_L : F2C772053E0B4D74 ID_BLOCK_L : 3904B6C0BEB3247C Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report to support! Include device info also! model letv x526 Reconnect Power/Cable! device info Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 02C5919D ID_BLOCK_I : 009900E1 ID_BLOCK_L : F2C772053E0B4D74 ID_BLOCK_L : 3904B6C0BEB3247C Use CM2 Internal Loader Error : Prepare target failed! Unsupported CPU??? Send log and report to support! Include device info also! |
10-20-2016, 14:47 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Team has just started with Qualcomm, just wait all will be added one by one. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
10-20-2016, 17:35 | #3 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Letv Using Own Loaders May Be... Or Try Once More .... Do Not Do All Procedure In Same Connection If Not Reboot Auto Do It Manually (Means Need To Reconnect N Put In EDL For Each Separate Operation).... |
10-20-2016, 21:05 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | SnapDragon 652 support will be activated in further QLM module versions. Need some time to collect more samples and make all things working perfect. |
