03-03-2011, 17:53 | #1 (permalink) |
No Life Poster Join Date: Aug 2005 Location: romania-bm Age: 40
Member: 174315 Status: Offline Thanks Meter: 123 | Iphone 911 dual sim help i try to format ffs , but i get error: COM3 [VCP1] selected module v3.13 Device: Autodetect 6228-6229 NOR Checking data, wait... advanced flash detection enabled Action: reset settings ("format ffs") ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6235:8A04:8A01]... CPU: MT6235 high speed boot On chip: 0000:0000:0003 status: FF boot packet size: 0400 Release Power button now ! in case of initial connection problem: on/off "Boot baudrate autoselect" Boot Fail Finished, time used: 17 sec Remove/Install battery now ! i tried via pinfinder , and i also soldered wires...but no succes. could this be the problem ? new cpu mtk..: CPU: MT6235 waiting for any suggestions |
03-04-2011, 09:54 | #4 (permalink) |
Member: 174315 Status: Offline Thanks Meter: 123 | already tried diferent settings/platforms , but no connection. phone needs a reset, to factory reset, because customer want to sell this phone. is not hardware related, phone is working fine |
03-04-2011, 10:53 | #5 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Try with "6235 Nor" option with latest Chinese Miracle3.27. Wr. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
03-04-2011, 11:21 | #6 (permalink) |
Member: 174315 Status: Offline Thanks Meter: 123 | booting problem was solved thx to PASSIONATE_BOYS now i have this: COM3 [VCP1] selected module v3.27 Device: Autodetect 6253 NOR Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0006]: 00EC:00A100000015 [SAMSUNG] K9F1G08Q0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (115200)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02620000/059E0000 firmware size: 38Mb ffs size: 89Mb detect sec ro... detect custom parameters... detect project-id... project-id: M800_MST_IP_MLD_18V_T06S0528 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_M800_MST_IP_M LD_18V_T06S052 nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.M800_MST_IP_ML D_18V_T06S0528.BIN project-id: M800_MST_IP_MLD_18V_T06S0528, 00000000 code offset: 00000000 ffs offset/size [01]: 02620000/059E0000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.27, database date: 01.03.2011): RATECH35_08B_PCB01_GPRS_MT6235B_S01.M800_MST_IP_ML D_18V_T06S0528.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== warning: can not format: HW_STORAGE_NOR is not present Format... Disconnect... done Finished, time used: 3 min 32 sec Remove/Install battery now ! |
03-04-2011, 11:57 | #7 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Now select "6228-6253 NAND" and format the set. Also if set is working fine then read full flash and send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage Please do not send flash if set is not working properly. You can see above highlighted line and can understand why I tell you to select 6228-6253 NAND option now. Wr. | |
The Following 2 Users Say Thank You to PASSIONATE_BOYS For This Useful Post: |
03-04-2011, 13:11 | #8 (permalink) |
Member: 174315 Status: Offline Thanks Meter: 123 | COM3 [VCP1] selected module v3.27 Device: Autodetect 6228-6253 NAND Checking data, wait... Action: reset settings ("format ffs") NAND interface: BROM_DLL_v3.1016.00 Connect... Phone should be Switched OFF ! Press and HOLD Power button now ! Connecting... Booting... Release Power button now ! bootcode current/expected: 3.2/3.2 CPU: 6235:8A04:8A01 status: FF bbchip bl ver: FE NOR flash chip: not installed NAND flash id[0006]: 00EC:00A100000015 [SAMSUNG] K9F1G08Q0M chip size: 128Mb page/spare size: 0800/0040 pages per block: 0040 bits i/o: 08 address cycles: 04 internal RAM size: 00010000 external RAM: S_DA_RAM_ERROR done Set baudrate (230400)... done ram test... testing... ram test passed ===> detect existing firmware structure... detect ffs... ffs offset/size: 02620000/059E0000 firmware size: 38Mb ffs size: 89Mb detect sec ro... detect custom parameters... detect project-id... project-id: M800_MST_IP_MLD_18V_T06S0528 detect NAND info... number of areas/bytes to read: 1:001A0000 reading (HW_STORAGE_NAND NUTL_READ_PAGE_ONLY)... nfi area detection... bootloader version: RATECH35_08B_BOOTLOADER_V005_MT6235B_M800_MST_IP_M LD_18V_T06S052 nfi area detection (3 cores) finished: Ok TCL-ID detection... TCL-ID detection done startup code area #1 detection... startup code area #1 detection done rom info ver: 07 sw version: RATECH35_08B_PCB01_GPRS_MT6235B_S01.M800_MST_IP_ML D_18V_T06S0528.BIN project-id: M800_MST_IP_MLD_18V_T06S0528, 00000000 code offset: 00000000 ffs offset/size [01]: 02620000/059E0000 rom info structure: [standard] type (07) TCL-ID is absent ===> done ==================== New firmware found (v.3.27, database date: 01.03.2011): RATECH35_08B_PCB01_GPRS_MT6235B_S01.M800_MST_IP_ML D_18V_T06S0528.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== warning: can not format: HW_STORAGE_NOR is not present Format... Disconnect... done Finished, time used: 2 min 16 sec Remove/Install battery now ! here is link with backup and txt file with logs http://rapidshare.com/files/450899735/New_Folder.rar |
The Following User Says Thank You to electrolandgsm For This Useful Post: |
03-04-2011, 22:24 | #9 (permalink) | |
Thank you very much ! We will check, prepare and upload files in support area as soon as possible. | |
03-06-2011, 23:04 | #10 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | As I can see phone was formatted well. NOR flash is not present and it was not formatted, but NAND flash was detected and format was done. |
The Following 2 Users Say Thank You to InfinitySupport For This Useful Post: |
