08-15-2008, 10:07 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Kumasi-Ghana
Member: 390204 Status: Offline Sonork: 100.1592805 Thanks Meter: 138 | please Fly-SL399E UNLOCK.... HELP Device: Fly-SL399E Checking data, wait... advanced flash detection enabled eeprom backup enabled, it may takes several minutes ! Action: unlock unlock method: standard fast Unlock procedure can be faster if you skip eeprom area backup procedure. Do you want to disable eeprom backup ? eeprom backup enabled Boot... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing[6219:8B02:8B01]... CPU: MT6219 CPU: MT6226MA detected chip: 0031741:F6AC boot step size: 0400 Release Power button now ! Boot Done Initialize... detecting chip #00 in region #00... flash: B0001D00000000:B0001D00000000 flash: Sharp Intel/Sharp ext [def 0004x008000 007Fx020000] 16Mb number of flash chip/regions detected: 01/01 Initialize Done Set baud... 921600 Set baud Done Initialize bootcode... Initialize bootcode Done Check firmware integrity... detect device identification#1... detection phase #1... detect device identification#1 finished identification#1 structure: 2nd [standard] generation identification#1 protocol ver: 04 ver. sw1: SL390M_MERID_UK_PCB01_GPRS_MT6226M_S01.SL390M.06A. W06.36.MP.V36.F2.BIN ver. sw2: SL390M.06A.W06.36.MP.V36.F2, 00000000 ffs offset/size: 00E00000/00200000 detect device identification#2... detection phase #1... . warning: optional information not found, if phone works well just ignore this warning detect device identification#2 finished Check firmware integrity Done Check firmware content... Check firmware content Done Backup required data... reading [eeprom[SL390M_MERID_UK_PCB01_GPRS_MT6226M_S01.SL390M.06A. W06.36.MP.V36.F2.BIN]]... file saved: C:\Program Files\InfinityBox\MModule\eeprom[SL390M_MERID_UK_PCB01_GPRS_MT6226M_S01.SL390M.06A. W06.36.MP.V36.F2.BIN]_20080815-090345.B0E.bin flash: B0001D00000000:B0001D00000000 Backup required data Done Patch required data... ................................................. lock area found Patch required data Done Special operation... Special operation Done Write... flash: B0001D00000000:B0001D00000000 flash: B0001D00000000:B0001D00000000 Write: lock-area-1 Write Done Finalization... Finalization Done Finished, time used: 125 sec Remove/Install battery now ! Please help me i select standard fast method... please help me |
08-15-2008, 13:38 | #2 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | There is a manual in support area: Infinity-Box-How_to_unlock_Fly-SL399E.txt |
fly sl399e unlock problem | sonetek | Infinity-Box | 20 | 04-14-2011 21:03 |
Fly SL399E UNLOCKING PROBLEM | ..::: Naveed :::.. | Infinity-Box | 9 | 09-06-2009 08:02 |
fly sl399e unlock | newerno | Infinity-Box | 1 | 11-23-2008 14:21 |
Fly SL399E Unlock problem | mobilewiz | Infinity-Box | 2 | 08-20-2008 14:16 |
Fly SL399E unlock | Anees-ur-rehman | Infinity-Box | 4 | 12-08-2007 12:54 |
