Please help alcatel 305 New firmware of alcatel 305, unlocked some models now they blink. here is full read flashfile http://rapidshare.com/files/44906136...part_1_of_1_20 |
Hi. Try to repair imei after unlock. What is the result ? |
COM12 [VCP0] selected module v3.62 Device: Alcatel-305X, 305A Checking data, wait... advanced flash detection enabled Action: "repair imei" new imei: 357769039097802 ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6223:8A05:8A00]... CPU: MT6223 chip: 0011:81A8:A00C status: 01 boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: 01227E22202200:2BEA0000000000 flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... .. usb bootloader detect (phase #2)... .. usb bootloader (chip) is absent searching rom info... search rom info finished rom info structure: [protected] type (05), 1 record(s) TCL-ID is present startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.2A66C 5E3.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_6065D886].rpl ==================== New firmware found (v.3.62, database date: 01.10.2010): JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished TCL-ID detection... TCL-ID detection done device-id: 2A66C5E3 rom info ver: 05 sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN project-id: MAUI.08A.W08.36.SP1.V34, 86D86560 code offset: 00000000 ffs offset/size [01]: 00C00000/00400000 TCL-ID identification version: 166 provider: 305X-2HVDKE1 customization: CP16CH12 customization: XP16CH12 TCL-ID identification done rom info structure: [protected] type (05), 1 record(s) TCL-ID is present ffs/eeprom address assigned: 00C00000 startup code area #1 check... startup code area #1 fixed sec info (detailed) detection... searching sec info#1... search sec info#1 finished sim-lock status: disabled product id: JRD_COMMUNICATION_U82X_PRODUCTS area1 is valid area2 is valid area3 is valid area4 is valid searching sec info#2... . search sec info#2 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... original imei: 35776903909780 flash: 01227E22202200:2BEA0000000000 Backup required data Done ====> Patch required data ... .............. pass #1 firmware remap[01]: 08000000 pass #2 firmware remap[01]: 08000000 ... pass #3 firmware remap[01]: 08000000 .............................. Patch required data Done ====> Special operation ... Special operation Done ====> Write ... flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: imei flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: imei flash: 01227E22202200:2BEA0000000000 flash: 01227E22202200:2BEA0000000000 Write: imei sec info (fast) detection... searching sec info#1... search sec info#1 finished searching sec info#2... . search sec info#2 finished security area (sec info, cust) calculation... identification header detected relocation table detected name table[00] #7000000 detected customization: CP16CH12 customization name adjusted customization: CP16CH12 customization name adjusted customization detected: CP16CH12 customization: CP16CH12 customization: XP16CH12 error: can't calculate security area (sec info, cust), existing data will be used Check support area for updates ! security area (sec info, cust) calculation done security area (sec info, hash) calculation... version is not found in database: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN use default security area (sec info, hash) pattern max address is too big, should be recalculated: 08BF8000->08631CD4 ..................security area (sec info, hash) detecting size... error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374 Write Done ====> Finalization ... ffs formatting... flash: 01227E22202200:2BEA0000000000 Finalization Done file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_2A66C5E3_6065D886_201 10224-111310.B0X.bin Finished, time used: 4 min 6 sec Remove/Install battery now ! File system has been modified ! It is need to press and HOLD phone "Power" button during long time (up to 1 min) to make phone Powered-On ! |
Did repair security area, formarted the set, then i repaired imei but still restarts on alcatel logo |
this phone not supported by infinity try another device |
@xtream 08 You must use latest MModule v3.75. Please, do not use half year old software ! @GFTELECOM You a liar ! You must think twice before post messages with lie ! |
