Old 02-21-2011, 08:57   #1 (permalink)
Member: 761820
Sonork: 100.1594410
Thanks Meter: 30
Please help alcatel 305
New firmware of alcatel 305, unlocked some models now they blink. here is full read flashfile
http://rapidshare.com/files/44906136...part_1_of_1_20
Old 02-21-2011, 10:34   #2 (permalink)
Member: 1043909
Thanks Meter: 60,926
Hi.
Try to repair imei after unlock.
What is the result ?
Old 02-24-2011, 09:24   #3 (permalink)
Member: 761820
Sonork: 100.1594410
Thanks Meter: 30
COM12 [VCP0] selected
module v3.62
Device: Alcatel-305X, 305A
Checking data, wait...
Action: "repair imei"
new imei: 357769039097802
====> Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
chip: 0011:81A8:A00C
status: 01
boot packet size: 0400
Release Power button now !
Boot Done
====> Initialize ...
flash: 01227E22202200:2BEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
otp offset: 00000000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
search rom info finished
rom info structure: [protected] type (05), 1 record(s)
TCL-ID is present
startup code area #1 is Ok
startup code area #1 backup saved: C:\Program Files\InfinityBox\MModule\backup_security\id.2A66C 5E3.[JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN_6065D886].rpl
New firmware found (v.3.62, database date: 01.10.2010):
This firmware is missing in support area. If this phone is good and working:
- download latest software from support area and try again, probably this firmware already supported in latest software
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to RapidShare AG, Cham, Switzerland or 4shared.com - free file sharing and storage
- include in your e-mail full text from phone back label (phone name etc.)
rom info detection finished
TCL-ID detection...
TCL-ID detection done
device-id: 2A66C5E3
rom info ver: 05
sw version: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN
project-id: MAUI.08A.W08.36.SP1.V34, 86D86560
code offset: 00000000
ffs offset/size [01]: 00C00000/00400000
TCL-ID identification
version: 166
provider: 305X-2HVDKE1
customization: CP16CH12
customization: XP16CH12
TCL-ID identification done
TCL-ID is present
ffs/eeprom address assigned: 00C00000
startup code area #1 check...
startup code area #1 fixed
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
sim-lock status: disabled
product id: JRD_COMMUNICATION_U82X_PRODUCTS
area1 is valid
area2 is valid
area3 is valid
area4 is valid
searching sec info#2...
search sec info#2 finished
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
original imei: 35776903909780
Backup required data Done
====> Patch required data ...
pass #1
firmware remap[01]: 08000000
pass #2
pass #3
Patch required data Done
====> Special operation ...
Special operation Done
====> Write ...
Write: imei
Write: imei
Write: imei
sec info (fast) detection...
security area (sec info, cust) calculation...
identification header detected
relocation table detected
name table[00] #7000000 detected
customization name adjusted
customization detected: CP16CH12
error: can't calculate security area (sec info, cust), existing data will be used
Check support area for updates !
security area (sec info, cust) calculation done
security area (sec info, hash) calculation...
version is not found in database: JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08A_W08_36_S P1_V34.BIN
use default security area (sec info, hash) pattern
max address is too big, should be recalculated: 08BF8000->08631CD4
..................security area (sec info, hash) detecting size...
error: security area (sec info, hash) size is incorrect: 01C0 instead of 0374
Write Done
====> Finalization ...
ffs formatting...
Finalization Done
file saved: C:\Program Files\InfinityBox\MModule\backup_security\Alcatel-305X,305A_JRD23_08A_PCB01_GPRS_MT6223P_S00.MAUI_08 A_W08_36_SP1_V34__system_log_2A66C5E3_6065D886_201 10224-111310.B0X.bin
Finished, time used: 4 min 6 sec
Remove/Install battery now !
File system has been modified !
It is need to press and HOLD phone "Power" button
during long time (up to 1 min) to make phone Powered-On !
Old 02-24-2011, 09:27   #4 (permalink)
Member: 761820
Sonork: 100.1594410
Thanks Meter: 30
Did repair security area, formarted the set, then i repaired imei but still restarts on alcatel logo
Old 02-24-2011, 10:07   #5 (permalink)
GFTELECOM's Avatar
Member: 922273
Sonork: 100.1583612
Thanks Meter: 119
this phone not supported by infinity try another device
Old 02-24-2011, 11:49   #6 (permalink)
Member: 1043909
@xtream 08
You must use latest MModule v3.75. Please, do not use half year old software !
@GFTELECOM
You a liar !
You must think twice before post messages with lie !
Old 02-24-2011, 18:16   #7 (permalink)
KYEJUSA's Avatar
Member: 394869
Sonork: TAKE NO CHANCES
Thanks Meter: 500
this model is fully supported by infinity,just use latest mmodule,will work fine without problems unlocked many sets.
The Following User Says Thank You to KYEJUSA For This Useful Post:
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.18583 seconds with 9 queries
