09-03-2018, 07:47 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: +62
Member: 1329173 Status: Offline Thanks Meter: 106 | Please help factory reset vivo 1723 RAM 6GB Code: Card found : XXXXXX , v0136 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : D3E60F15 ID_BLOCK_E : 00730004 ID_BLOCK_L : AFEBE8E232C6922F6D9FCF1391EC5B46 ID_BLOCK_L : 718F5C753BEF95076C35872B09E76243 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : D3E60F15 ID_BLOCK_E : 00730004 ID_BLOCK_L : AFEBE8E232C6922F6D9FCF1391EC5B46 ID_BLOCK_L : 718F5C753BEF95076C35872B09E76243 Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Operation : EDL Security Operation [ v1.16 ] |
09-03-2018, 07:58 | #4 (permalink) | |
Product Supporter Join Date: Jun 2014 Location: India
Member: 2211790 Status: Offline Thanks Meter: 5,118 | Quote:
09-03-2018, 13:31 | #5 (permalink) |
Member: 1329173 Status: Offline Thanks Meter: 106 | Load it's factory file is damaged Code: Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Loading firmware ... Firmware load error! Firmware damaged or in unknown format! Send report to support! Loading firmware ... Firmware load error! Firmware damaged or in unknown format! Send report to support! Loading firmware ... Firmware load error! Firmware damaged or in unknown format! Send report to support! |
09-03-2018, 13:59 | #6 (permalink) | |
09-03-2018, 15:10 | #7 (permalink) | |
Member: 1329173 Status: Offline Thanks Meter: 106 | Quote:
Format CACHE ... Format failed! Remove FRP Additional data remove failed! Code: Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : D3E60F15 ID_BLOCK_E : 00730004 ID_BLOCK_L : AFEBE8E232C6922F6D9FCF1391EC5B46 ID_BLOCK_L : 718F5C753BEF95076C35872B09E76243 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00000000 Boot Ok! Brand : vivo ProdName : sdm660_64 ProdModel : vivo 1723CF Device : sdm660_64 AndroidVer: 8.1.0 Manufact. : vivo SysPatch : OPM1.171019.011 DevComTime: 02/07/2018 12:13:50 USERData : ENCRYPTED GCSec : NORMAL Done! Elapsed: 00:00:39 Reconnect Power/Cable! Operation : Reset Settings [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : D3E60F15 ID_BLOCK_E : 00730004 ID_BLOCK_L : AFEBE8E232C6922F6D9FCF1391EC5B46 ID_BLOCK_L : 718F5C753BEF95076C35872B09E76243 Pickup loader from firmware package Loader Sent! Initializing ... Running FireHose on BBID : MSM8996 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0001C000/0001C000/00001000/00001000/00000000 Boot Ok! Format USER ... Format CACHE ... Format failed! Remove FRP Additional data remove failed! Done! Elapsed: 00:02:35 Reconnect Power/Cable! | |
09-03-2018, 15:43 | #8 (permalink) |
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Hello, Wht is the condition of mobile,,Check emmc state from memory tool |
The Following User Says Thank You to princesaddam For This Useful Post: |
09-21-2018, 18:28 | #9 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Negeri Para Penipu
Member: 142211 Status: Offline Thanks Meter: 90 | same, not work Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 660 [MSM8956 Plus] ID_BLOCK_S : DEA139C2 ID_BLOCK_E : 00730004 ID_BLOCK_L : FA98BBB74193ED5AC0CCBA64EEB10E2B ID_BLOCK_L : B45497B0E02A5AC2B1FE42ECC62AA79E Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
09-22-2018, 08:41 | #10 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Wait for update to get it supported! Br. Infinity Box Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
