Old 11-19-2009, 11:03   #1 (permalink)
Member: 283534
Thanks Meter: 12
Please help files N86i
Please help files N86i two sim. thank.
read from infi
File download
HEXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C0 20_3_3_1_MP_V1__fullflash_20091118-160128.B0M.bin
Old 11-19-2009, 18:55   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
read from infi
File download
Hello,
Is it backup from good working phone or from damaged phone ?
The Following User Says Thank You to InfinitySupport For This Useful Post:
Old 11-20-2009, 02:58   #3 (permalink)
Member: 283534
Thanks Meter: 12
Originally Posted by InfinitySupport View Post
Hello,
Hello, backup from damaged phone , at first not get sim only. Thank.
Old 11-20-2009, 05:47   #4 (permalink)
Member: 283534
Thanks Meter: 12
pictures MOBILURI QuickShare n86i
Old 11-20-2009, 18:31   #5 (permalink)
Member: 130995
Hello,
If required file can not be found in support area (please use "search" function in support area first)
it will be good if somebody can read full flash from the same good working phone and send
full flash backup to [email protected] so we will be able to prepare and upload
good working files in support area for all users.
Here is an instruction how to make "search" in support area: http://forum.gsmhosting.com/vbb/showthread.php?t=499453
Please, DO NOT send to us backup files from damaged phones. We CAN NOT repair damaged files !
Old 11-21-2009, 15:37   #6 (permalink)
Member: 283534
Thanks Meter: 12
Is it backup from good working phone, at first not get sim only. Other new file ran dead.
Old 11-22-2009, 01:47   #7 (permalink)
Member: 148515
Thanks Meter: 19,534
hello!
can you post a log where you flashing phone by this good working backup?
Old 11-27-2009, 12:40   #8 (permalink)
Member: 283534
Thanks Meter: 12
hello!
Hello!
files on the support are not yet on the white screen, help me.
==== log: [11/18/2009 3:43:55 PM] ====
COM8 [VCP1] selected
module v2.96
Device: Autodetect 6205-6227 NOR
Checking data, wait...
Action: read NOR flash
Boot ...
19200 fixed
Connecting, wait...
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:AF16:000C
status: FF
boot packet size: 0400
Release Power button now !
Boot Done
Initialize ...
flash: 98000300000000:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
detecting chip #01 in region #00...
detecting chip #02 in region #00...
detecting chip #03 in region #00...
number of flash chip/regions detected: 04/01
Initialize Done
Set baud ...
230400
Set baud Done
Initialize bootcode ...
Initialize bootcode Done
Check firmware integrity ...
device parameters autodetection in progress...
it's time to stop: 2B0000EA18F09FE518F09FE518F09FE518F09FE518F09FE5
total flash region size: 01000000
searching rom info...
search rom info finished
rom info structure: 2nd [enhanced] generation
TCL-ID is absent
startup code area #1 is damaged, recalculation required
rom info detection finished
device-id: 5F8F2ED1
rom info protocol ver: 04
ver. sw 1: HEXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C0 20_3_3_1_MP_V1.BIN
ver. sw 2: PRJ_C020_3_3_1_MP_V1, 96BF1DCA
address offset: 00000000
ffs offset/size: 00E00000/00200000
detecting ffs/eeprom area in 1 chip(s)...
standard ffs/eeprom offset detected: 00E00000
checking area [00000000]: 00000000-00FFFFFF...
ffs/eeprom found near: 00E00000
detecting ffs/eeprom size...
ffs/eeprom size: 00200000
ffs/eeprom chip: 00
ffs/eeprom area: 00000000:00E00000-00FFFFFF
sec info (detailed) detection...
searching sec info#1...
search sec info#1 finished
Check firmware integrity Done
Check firmware content ...
detecting languages...
language parameters detected
detected languages: En Th Vn
Check firmware content Done
Backup required data ...
reading: HEXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C0 20_3_3_1_MP_V1__fullflash...
file saved: C:\Program Files\InfinityBox\ChineseMiracle\HEXING23C_08A_GEM INI_PCB01_GPRS_MT6223P_S00.PRJ_C020_3_3_1_MP_V1__f ullflash_20091118-160128.B0M.bin
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H EXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C02 0_3_3_1_MP_V1__system_log_5F8F2ED1_CA1DBF96_200911 18-160224.B0X.bin
Finished, time used: 1106 sec
Remove/Install battery now !
Old 11-27-2009, 18:54   #9 (permalink)
Member: 148515
hello!
Do you have original backup? to restore phone to previous state?
Old 11-28-2009, 05:31   #10 (permalink)
Member: 283534
Thanks Meter: 12
Hello,
original file here ,
read from infi
File download
==== log: [11/18/2009 4:24:00 PM] ====
module v2.96
Action: write NOR flash
"smart write" active
write: Firmware
skip: Customization/Language Pack
skip: Customization
write: Eeprom/ffs
HEXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C0 20_3_3_1_MP_V1__ffs_20091118-161648.B0E.bin
Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize ...
Initialize Done
Set baud ...
230400
Set baud Done
TCL-ID is absent
device-id: 5F8F2ED1
Backup required data Done
Patch required data ...
Patch required data Done
Special operation ...
Special operation Done
Write ...
sec info (fast) detection...
startup code area #1 check...
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.5F8F2ED1.[HEXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C0 20_3_3_1_MP_V1.BIN_CA1DBF96].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\id.5F8F2ED1._HEXI NG23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C020_3 _3_1_MP_V1.BIN_CA1DBF96_.rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5F8F2ED1.[HEXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C0 20_3_3_1_MP_V1.BIN_CA1DBF96].rpl
warning: rpl file not found: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\i d.5F8F2ED1._HEXING23C_08A_GEMINI_PCB01_GPRS_MT6223 P_S00.PRJ_C020_3_3_1_MP_V1.BIN_CA1DBF96_.rpl
warning: unknown rom info structure: HEXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C0 20_3_3_1_MP_V1.BIN_CA1DBF96
Unknown firmware detected (v.2.96, database date: ), user action required:
1. download latest software from support area and try again
2. if no still luck follow the next procedure:
- find good working phone with the same firmware:
- make "Read full flash" operation
- send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com
- include in your e-mail full text from phone back label (phone name etc.)
- be little bit patient and wait update
error: startup code area #1 can't be fixed
detecting startup code area #2...
startup code area #2 is absent
You can flash phone now but can not finalize it.
In most cases phone CAN NOT power-on.
Do you want to continue anyway ?
operation aborted
file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\H EXING23C_08A_GEMINI_PCB01_GPRS_MT6223P_S00.PRJ_C02 0_3_3_1_MP_V1__system_log_5F8F2ED1_CA1DBF96_200911 18-162536.B0X.bin
Finished, time used: 93 sec
Old 11-28-2009, 21:36   #11 (permalink)
Member: 148515
hello!
and what happends after restoring back original backup file?
Old 11-29-2009, 13:27   #12 (permalink)
Member: 283534
Thanks Meter: 12
hello,
phone always dead after restoring back original backup file.
The Following User Says Thank You to minh tan For This Useful Post:
Old 11-30-2009, 18:34   #13 (permalink)
Member: 148515
hello!
we will release support for this firmware version in next Chinese Miracle update
Old 12-03-2009, 13:50   #14 (permalink)
Member: 283534
Thanks Meter: 12
New flash files uploaded in support area:
Chinese models:
F93B_PCB01_GPRS_MT6225_S00.MAUI_GEMINI_W08_12_16m_ En_Cn
HAOCHENG25_08A_PCB01_GPRS_MT6225_S00.DSC_V128C_01_ A1_T09_0924V1_8_16m_En_Cn
MX9_YHD_PCB01_GPRS_MT6225_S00.V1_00_13_M090915CN0-V1F3_16m_En_Cn
CK.E71TV.E11.F1.1.5.T11D090417__Nokia-E72_16m_En_Fr_Es_Id_Tr_Farsi_Pt_Ar
MAUI25_GEMINI_PCB01_GPRS_MT6225_S00.S151_S_F_B_S_V 12__Goldvish-Creative_16m_En_Ru_Fr_Es_De_Id_Th_Vn_Pt
TELSDA25_07B_PCB01_GPRS_MT6225_S00.V9_V02_0_0930__ Vertu-Signature-RM266V_16m_En_Ru_Fr_Id_Vn_Tr_Pt
APPLE_G580_MULTI_PCB01_GPRS_MT6225_S00.CREATONE_G5 80__iPhone-KA08-2sim_16m_En_Nl_Fr_Es_It_De_Ml_Id_Tr_Farsi_Pt_Ar
CELLTEL25_GEMINI_PCB01_GPRS_MT6225_S00.CBM18_S_ZH_ V15_16m_En_Ru_Fr_Id_Ar
E80L9EN_GEMINI_PCB01_GPRS_MT6225_S00.E80_LONGE_L9E N_P1_V08_090318_QCIF_CM30_TO75_CTF_BT_FM__Vertu-Ascent-Ti_16m_En_Ru_Fr_Es_Pl_De_Ml_Id_Ar
Q260HRD_ALL_PCB01_GPRS_MT6223P_S00.Q260_38A0_V8_0_ 4__Nokia-SZL_16m_En_Ru_Fr_Es_It_Ml_Id_Th_Vn_Tr_Farsi_Pt_Ar
BAIQI25_GEMINI_PCB01_GPRS_MT6225_S00.Q10_A_PLD_A2_ MP_V106_16m_En_Cn
TELSDA25_08A_GEMINI_PCB01_GPRS_MT6225_S00.N95_OV76 70_7680_ML_GEMEIXUN_V1__Nokia-N95-8Gb_16m_En_Gr_Fr_Ro_Pl_Tr
U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V02B50_16m_E n_Cn
BAIQI25_GEMINI_PCB01_GPRS_MT6225_S00.Q10_A_PLD_A2_ MP_V106_En_Cn
BAIQI25_GEMINI_PCB01_GPRS_MT6225_S00.Q10_PLD_A2_LA NG2_MP_V001_En_Ru_Gr_Fr_Es_It_De_Pt
HQX_H610B_02_PCB01_GPRS_MT6225_S00.LB8CZ03_8_5_1_0 T01M0925_M504A_16m_En_Gr_Fr_Es_It_De_Id_Vn_Tr_Pt_A r
LCSH23C_07B_PCB01_GPRS_MT6223P_S00.N_V101_Y50M10_0 407_07B0816M_1_3D090527C01_16m_En_Ru_Fr_Pt_Ar
M6225_DUAL_PCB01_GPRS_MT6225_S00.V04_20_16m_En_Ru_ Fr_Es_De_Th_Vn_Cn_Tr_Farsi_Pt_Cn_Ar
MT6226_06A_PCB12_GPRS_MT6226_S01.W998_16m_En_Cn
U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V06B01_16m_E n_Cn
U25_06B_PCB01_GPRS_MT6225_S00.UPU25U26V06B02_16m_E n_Ru_Ml_Id_Th_Vn
TECHAIN23_08A_F_PCB01_GPRS_MT6223_S00.T366_S03_1_S JHXF_090709__Nokia-N3216_16m_En_Ru_Fr_Es_De_Id_Th_Vn_Tr_Farsi_Pt_Ar
N95_25_PCB01_GPRS_MT6225_S00.A95_L11EN_V209_090925 _IN097_9331_GC0307_FM5800_PRDA__Nokia-N95-8GB-RM-117_5pin_64m_En_Ru_Nl_Fr_Es_Id_Th_Vn_Tr_Pt_Ar
SZMI26_05C_ELIDA_PCB01_GPRS_MT6226_S01.S650D_ELIDA _V1_5__HB-760-2sim_16m_En_Ru_Th_Vn_Cn
GEMINI_PCB01_GPRS_MT6225_S00.L_2428A_091012_V2_1_5 _T4__Nokia-Xpress-Music-KA09_16m_En_Ru_Fr_Es_It_De_Ml_Id_Th_Vn_Tr_Farsi_Pt _Ar
M310_HW10S011_MULTI081204__Tonsin-MM79-dual-sim_16m_En_Fr_Es_De_Id_Tr_Farsi_Pt_Ar
NEOTEL25_GEMINI_PCB01_GPRS_MT6225_S00.GP2537_5800_ SM__Nokia-Xpress-Music-KA09_16m_En_Fr_Es_It_De_Tr_Farsi_Pt_Ar
SCUD_GEMINI_PCB01_GPRS_MT6225_S00.615_V04__F168+_1 6m_En_Ru_Fr_Es_De_Ml_Id_Th_Tr_Farsi_Pt_Ar
TG01_PCB01_GPRS_MT6225_S00.TG01_V6_1_0__SciPhone-i9+++_32m_En_Ru_Nl_Fr_Es_It_De_Vn_Tr_Pt_Ar
Hello,
this machine find not see , help me.
Old 12-03-2009, 17:14   #15 (permalink)
Member: 130995
Hello,
Files uploaded in "main" support area mirror.
Rest support area mirrors will be updated in 1 day.
FG TEAM please help file LG U880 ,,urgent diva2812 FuriousGold 6 03-12-2010 13:52
PLEASE HELP FILE FLASH TiPhone T80 bintara Chinese Models & Cloned Phones 0 01-13-2010 15:32
Please Help file Bluetooth_V128a vuonghungmobile Infinity-Box 5 03-15-2009 02:59
please help file flash st88 frank_pacific_o SpiderMan 3 12-29-2008 17:31
please help,..file 6138 rom3 arema Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 04-05-2003 12:16
Page generated in 0.29148 seconds with 9 queries
