06-25-2019, 22:52 | #1 (permalink) |
Freak Poster Join Date: Mar 2017 Location: Zimbabwe
Member: 2692778 Status: Offline Thanks Meter: 49 | Please help fix imei on this alcatel 5058a Card found : F0DCCAE2 , v0138 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.06 Load IDBase v123080 Ok! Preloader [HW DEV] Info : EMI : DEV : EMI : SRC : EMI : CNT : 0000 Operation : Write Flash [ v2.06 ] Repartition : Enabled Flash Verify : Enabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :17 [FL] : Set : preloader_aus6739_66_n1.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.bin [FL] : Set : mcupmfw.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : loader_ext.img [FL] : Set : loader_ext.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : trustzone.bin [FL] : Set : trustzone.bin [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xD08A7BAC [ 3.26 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : COMIO : GEN_MT6739 | Manual : Disabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : EMI : SRC : EMI : CNT : 0000 EMI : Init EMI from INTERNAL DB DA : SETUP EMI PARAMS FAILED! ERROR : ERROR Error : Fail to init protocol! Internal EMI : Select other EMI number! External Preloader - make sure it correct for connected device! Reconnect Power/Cable! EMI : DEV : MT6739 EMI : SRC : preloader_aus6739_66_n1.bin EMI : CNT : 0002 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 110100303136473330 : VEN : TOSHIBA | DEV : 016G30 : RAM : [ 2.00 GB ] Operation : Write Flash [ v2.06 ] Repartition : Enabled Flash Verify : Enabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :17 [FL] : Set : preloader_aus6739_66_n1.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.bin [FL] : Set : mcupmfw.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : loader_ext.img [FL] : Set : loader_ext.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : trustzone.bin [FL] : Set : trustzone.bin [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xD08A7BAC [ 3.26 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek DA USB VCOM (Android) (COM15) MODE : PRELOADER PORT PORT : 15 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Write Flash [ v2.06 ] Repartition : Enabled Flash Verify : Enabled Reg.Pre-Erase : Enabled Verify HW/SW : Enabled SData Backup : Disabled Safe UserData : Disabled Files :17 [FL] : Set : preloader_aus6739_66_n1.bin [FL] : Set : recovery.img [FL] : Set : md1rom.img [FL] : Set : md1dsp.img [FL] : Set : spmfw.bin [FL] : Set : mcupmfw.img [FL] : Set : lk.bin [FL] : Set : lk.bin [FL] : Set : loader_ext.img [FL] : Set : loader_ext.img [FL] : Set : boot.img [FL] : Set : logo.bin [FL] : Set : trustzone.bin [FL] : Set : trustzone.bin [FL] : Set : system.img [FL] : Set : cache.img [FL] : Set : userdata.img [FL] : Total size : 0xD08A7BAC [ 3.26 GB ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : COMIO : GEN_MT6739 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6739 EMI : SRC : preloader_aus6739_66_n1.bin EMI : CNT : 0002 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 110100303136473330 : VEN : TOSHIBA | DEV : 016G30 : RAM : [ 2.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 110100303136473330004FF1290584ED EMMC: VEN : TOSHIBA | OEM : 01 | DEV : 016G30 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6B07262161D61C53617DC35A403CA33 DA : USB : HIGH-SPEED Boot done! [FL] : HW verification passed! SEC_DL : False (RAPHAEL) OK SEC_ID : 0x494E46494E495459424F584245535432 [FL] : Pre-Erase Erase : 0x0000000000000000 : 0x0000000002E88000 Erase : 0x0000000003688000 : 0x0000000004000000 Erase : 0x0000000008800000 : 0x0000000000A00000 Erase : 0x0000000009500000 : 0x0000000007200000 Erase : 0x0000000010C00000 : 0x0000000000200000 Erase : 0x0000000010E20000 : 0x000000024C9E0000 [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing now ... Write : PRELOADER Update bootloader backup copy ... Update bootloader backup copy Ok! Write : RECOVERY Write : MD1IMG Write : MD1DSP Write : SPMFW Write : MCUPMFW Write : LK Write : LK2 Write : LOADER_EXT1 Write : LOADER_EXT2 Write : BOOT Write : LOGO Write : TEE1 Write : TEE2 Write : SYSTEM Write : CACHE Write : USERDATA [FL] : RePartition [FL] : RePartition Ok! [FL] : Flashing finished! Done! Elapsed: 00:04:00 Reconnect Power/Cable! Operation : Identify [ v2.06 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek USB Port (COM6) MODE : BOOTROM PORT : 6 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : COMIO : GEN_MT6739 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA.bin AGENT : Found MT6739 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : DEV : MT6739 EMI : SRC : preloader_aus6739_66_n1.bin EMI : CNT : 0002 EMI : [00] : eMCP : eMMC+LP/DDR3 , ID : 150100514536334D42 : VEN : SAMSUNG | DEV : QE63MB : RAM : [ 2.00 GB ] EMI : [01] : eMCP : eMMC+LP/DDR3 , ID : 110100303136473330 : VEN : TOSHIBA | DEV : 016G30 : RAM : [ 2.00 GB ] EMI : Init EMI from PRELOADER EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0x80000000 [ 2.00 GB ] EMMC: 110100303136473330004FF1290584ED EMMC: VEN : TOSHIBA | OEM : 01 | DEV : 016G30 EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x3AB400000 [ 14.68 GB ] CHIP : MT6739 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 6B07262161D61C53617DC35A403CA33 DA : USB : HIGH-SPEED Boot done! Patch Level : N6F26Q Display ID : 5058A_LATAM_V1.1_171107 Ver. CodeName : REL Ver. Release : 7.1.1 Sec. Patch : 2017-11-05 Build Time : 1510292687 Product Model : 5058A Product Brand : ALCATEL Product Name :ALCATEL 5058A Product Device : A3A PLUS by AlcatelProduct Manfct : alps Board Platform : mt6739 Product Info : A3A PLUS USERDATA : ENCRYPTED NVRAM check : Failed! NVRAM empty! Done! Elapsed: 00:03:16 |
06-26-2019, 04:26 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | So, just make Fix BB and check after in setting - about. BaseBand must be alive, not "unknown". Imei should also come back. |
