Old 12-23-2008, 10:58   #1 (permalink)
Member: 759285
Thanks Meter: 4
please help i am new please
whenever i connect my infinity box with the pinfinder it finds the tx and the rx corectly but the software ask me to PRESS AND HOLD POWER BUTTOON which i did for more than 30mins nothing happen. why? even when i want to do even unlocking, read users code or format FFS in any phone
Old 12-23-2008, 17:26   #2 (permalink)
Member: 130995
Thanks Meter: 35,227
Hello,
What phone you talk about ?
I hope that you did not tried to use phone battery but you use PinFinder "Power" wires during connection.
Old 12-24-2008, 08:24   #3 (permalink)
Member: 759285
Thanks Meter: 4
You are really a Master i was using phone battery because the output voltage from the box was 4.83v and when connected to the pinfinder the power wires could not power phones. after a sometimes it show ...........error #1. please help
Old 12-24-2008, 18:47   #4 (permalink)
Member: 130995
Hello,
Please, check PinFinder manual page-20, you will see an easy instruction how to fix problem with low voltage.
Old 12-26-2008, 08:44   #5 (permalink)
Member: 759285
Thanks Meter: 4
Red face please i need advice from everyone
my infinity pinfinder cant detect any pinout but the output voltage from the infinty box is 4.83v since it was not up to 5.0v i have to short circuit the diode as instructed in the manual but no way forward. Why? when i select pinout manually it says PRESS AND HOLD THE POWER BUTTON which i did for more than 30mins and it latter says CONNECTION ERROR #1 . WHY?
Old 12-26-2008, 10:27   #6 (permalink)
Member: 130995
Hello,
What is voltage value at unibox pin-1 now ?
What phone you have tested for pinout selection/detection ?
Old 12-29-2008, 12:26   #7 (permalink)
Member: 759285
Thanks Meter: 4
thanks the pinfinder couldnot detect the phone so i have to use a friend mtk box but with infinity interface. the phone is ok now thanks
Old 12-29-2008, 12:51   #8 (permalink)
Member: 130995
@edos.harry
Thank you very much for your total ignorance !
It is very good example of zero respect.
yes, let's continue this way, let's ignore questions and advices: http://forum.gsmhosting.com/vbb/show...59&postcount=6
Old 12-30-2008, 10:44   #9 (permalink)
Member: 759285
Thanks Meter: 4
with due respect i accept i all faults because i am new to this infinity box. it was configuration problem a friend has com to fix everything all is working now thanks for your contribution and advice
Old 12-30-2008, 11:12   #10 (permalink)
Member: 130995
Hello,
We are very glad to see that your problem was solved.
Anyway, if you want to fix and possible problems with PinFinder you must check voltage at unibox pin-1 as a first step.
I am new...Please help with Flash!!!! tommyvo Cyclonebox 10 06-13-2009 05:56
please i need help i am new user masad UST Pro II 2 11-28-2007 12:41
HWK Killer Please Help I Am New To UFS 3 mobilelatham UFS2 + UFS3-Tornadoflasher 1 07-03-2007 10:18
K300 error HELP!!!! i am new at this....thanks Maykoid SonyEricsson (USB-Smart) 7 02-07-2006 06:10
Help i am new buha Sim Cloning and Scaning 4 07-17-2003 10:57
Page generated in 0.19831 seconds with 10 queries
